Reverting blanket rezoning is not the real issue at hand. Council is also trying to slash RCG typology from 4+4 to 3+0 based on density calculation (75 UPH v 60 UPH) and interpretation of Unit (vs suites)
This will effectively eliminate new family-sized rental housing in Calgary's established communities.
The moment you need to increase your living situation from 2-bed to 3-bed, you're forced to the suburbs.... unless you have $1m for a new infill.
Was this in the Dec. 15 meeting? I saw the 75 to 60 change, but I didn't catch the interpretation of units/suites? I presume this is the motion:
The crazy thing with that is I think most 'pro-housing' voted in favour of the RCG redesign thinking that they were somehow helping, when in reality they are essentially creating an un-buildable form.
Assuming this was the motion arising above that was edited on the fly, I believe Chabot suggested that it was just a starting point to be further refined at the public hearing in March. Which doesn't make sense to me as this sounds pretty darn prescriptive and would mean they'd be editing it on the fly again in March.
Maybe I'm missing something, but it certainly doesn't seem like the thoughtful process to replace blanket rezoning with something better and more strategic like they promised.
Funny too how all the anti-R-CG folks voted against it, they see it as bad for them strategically.
I think the play is to go to the Public Hearing and pitch these as mutually exclusive. Either you make R-CG more incremental from the current built form to H-GO, such that it would be politically palatable enough to remain everywhere - or you go back to regulating it like nuclear waste, with special Council approval required each and every time, while keeping it viable.
Otherwise developers will see that it's the same LOC process to get R-CG as it is to get H-GO or M-CG, and they'll just go for those.
I had hoped that this was where things might head, but it seems clear that at least 8 votes are set in stone (but probably more). I think the RCG revisions will be for a new framework/strategy to approach the missing middle, but it seems the first attempt towards a new framework failed.
I had to go back and check because it was hard to follow the motions arising without looking at the minutes. After they passed the preliminary RCG tweaks the final motion arising was this - Schmidt leads by acknowledging it was written by Farkas
So a lot to unpack there, but I think you can boil it down to: direct admin to figure out a framework alternative to blanket rezoning, and make sure we keep access to funding like HAF.
Earlier in the meeting Farkas said:
“Federal officials confirmed that compliance with the Housing Accelerator Fund is assessed based on housing outcomes, not the use of any single zoning tool. Blanket rezoning was not identified as a legal requirement of the HAF contribution agreement,” he told councillors.
Farkas said he “explicitly” asked Minister Champagne about the elimination of citywide rezoning from the Land-Use Bylaw, and the minister told him that they supported “a flexible approach that respects local decision making.”
But LWC seems to share my sense that the matter isn't fully settled.
“We are aware of Calgary’s proposal and are reviewing the details, but we’ve said both publicly and in conversations with the City of Calgary that we expect municipalities to fulfill the agreements they signed with the federal government in order to get access to federal funds,” read the emailed statement from office spokesperson Renée LeBlanc Proctor.
“If a partner’s agreed upon commitments aren’t met or are reversed, this puts their HAF funding at risk.”
Government sources have also told LWC that a final decision on Calgary’s HAF funding hasn’t yet been made.
The HAF funding agreement does reference exclusionary zoning and making changes related to broad upzoning allowing more housing choice.
The mayor also said that he spoke with provincial officials, who expressed support for a local approach.
“They pledged to forcefully advocate for and defend Calgary’s interests with the federal government, should council choose to proceed in that direction, including with respect to maintaining HAF funding,” Farkas said.
Farkas said that, technically, the HAF agreement involves the province and the federal governments.
I would speculate that the motion above that failed was probably an important step in fully satisfying the feds. I imagine we will still get there eventually, but I'm not taking anything for granted with this council. And then the provincial element adds another layer of interest...the UCP might love to have a grievance like this against the feds...
"This motion explicitly says deliver housing at-scale... this will lead us to blanket zoning with a different name."
- Actual Thing That Councillor Rob Ward Said, Like Actually
I wonder if we'll see a big push of development applications before Council blows it all up in March or if the timelines are just too tight for most developers to get new projects in under the wire?
I've been wondering the same. From what I've heard, some builders had purchased land and were waiting to pull the trigger once the blanket zoning was in place, and coupled with the huge population spike, there were even more infill developments. If I had to take an educated guess, I would expect the infill boom would have gradually slowed, but now with it being repealed it might be a case of pedal to the metal, and then a sudden screech.
Sorry to be lazy, but is there any TLDR of what council has already changed to the City wide zoning bylaw, and why the vote on updating it isn't until April? Just assumed it would be early given the election heat around this issue.
Council has directed Administration to do two things.
1. Prepare a bylaw to repeal blanket rezoning and go back to the old zoning with a caveat that any development permit obtained prior to the repeal date will be grandfathered in.
2. Prepare a bylaw to heavily modify what is permitted as part of R-CG zoning.
Council will debate both bylaws and hear from the public on them in March. The reason why it can't occur any sooner is that bylaw modifications like the ones being proposed have strict public advertising timelines and so in order to comply with the requirements of the Municipal Government Act, March is pretty much the soonest anything can happen.
Personally I'm almost more concerned with #2 versus #1. Repealing blanket rezoning is going to add cost and delay to infill projects but there is still the opportunity for them to get built after a developer jumps through the hoops.
I've been told by people smarter than me that the modifications to R-CG that Council has directed Administration to make will essentially make it completely unfeasable to build any sort of in-fill project using R-CG ever again. The worst part is these amendments were supported by many of the pro-housing Councillors and the entire conversation has flown under the radar because everyone is so focused on the blanket rezoning repeal instead.
