 8.8K     0
 5K     0
What is the upper limit of a street running streetcar line? With all the obstacles that King streetcars have had to deal with for so long, it has to be significantly higher than 65,000. What's the busiest street running streetcar line in the world? How busy is it? Without this information I'll accept the city's ridership numbers more than your skepticism. I'm well aware that the city uses antiquated methods of counting riders, but there's no indication that the methodology has changed or deteriorated. If the current ridership numbers are unreliable, the the previous ridership numbers must be equally unreliable. So if the counts are showing suddenly higher numbers, there's another reason for the change than the way the TTC counts riders.
Speed improvements have been as high as 4-5 minutes in rush hour. Reliability has improved as well. That kind of time savings means streetcars are about 20-24% faster in rush hour (less for the day as a whole). Those numbers could potentially improve further as the pilot is modified and refined. The faster speeds alone can move significantly more people without any new vehicles being added to the line. Increased reliability can increase capacity further. Add in the fact that they're using more Flexity LRVs which carry more people and have faster boarding and the line carrying 20% more passengers seems pretty realistic to me.
Travel times within the pilot area have decreased, those vehicles must turnaround on cherry/dufferin or continue to their terminals to come back the other way. A 25% increase in speed in the pilot area does not equate to a 25% increase across the entire route....the capacity in the pilot area is physically constrained by the number of vehicles that travel through the corridor, which has nothing to do with travel times, and has everything to do with headways and frequencies. A decrease in travel time theoretically means more vehicles can be throughput, however, real increases in the number of vehicles that can be allotted is constrained by King Street's operations on the peripheries. You can change the goal posts however you choose, but at the end of the day the math has to check out.
My post was an assumption that I actually think the baseline ridership was probably higher than they calculated, and the introduction of better counting technology erroneously showed a higher increase than what realistically occurred. Yes, there was likely an increase but I don't see how the numbers, when you break them down can in any way lead to a 25% increase in ridership across the line (which is what was stated by numerous people). Even a 25% increase eastbound at Spadina is hard to believe.
TTC also have Presto data now (which is why they were able to say Queen ridership has not materially declined). The precision of their data can be argued but the accuracy is likely sufficient for the purposes of the pilot.
PRESTO adoption on the TTC is ~1.4M transactions a week. http://www.metrolinx.com/en/docs/pdf/board_agenda/20170628/20170628_BoardMtg_PRESTO_Report_EN.pdf Typical week DAY ridership on the TTC is ~2.7M https://www1.toronto.ca/wps/portal/contentonly?vgnextoid=c077c316f16e8410VgnVCM10000071d60f89RCRD . Presto adoption still isn't very high, although, yes, you're right, it'll help make counting much more accurate going forward.
What I was trying to say is, yes, I 100% believe the recent figures on ridership are very accurate, however, I think the stated increase of 25% is because the original ridership was under-counted. Anyway, that's my thoughts on it, could be wrong, could be right. semantics really.
King is certainly near the top of the list for a shared row in a developed country (streetcar or bus). IIRC, some of the MTA bus routes hit 100k in the early 2000's but their ridership has halved since then.
Hong Kong tramways, which can be considered a single line with a couple branches, has daily ridership of about 180,000. Of course, they also run double-decker trams that are packed mid-day with tourists. Dedicated ROW in parts but most of the route shares lanes with vehicles. Stops are every 250m too, so definitely local service like King.
The highest daily ridership of a Melborne line is about 40,000. I expected higher when I looked.
I'd agree, not least because the priority signalling of even the more primitive type is not enabled, let alone a state-of-the-art system that controls intersecting traffic and lights as well as control the streetcar speed, interval/headway and priority at lights and time dwell at stops. This is of course the City's domain as much as the TTC's. It keeps being repeated that speed is not the end-all of this exercise as that pertains to capacity, but that fails to understand the importance of *throughput* as much as each car's actual capacity at any given time. I suspect a theoretical capacity, with optimized signalling and control, and with the present infrastructure and speed limits, is about 50% greater.
Excellent rationale, but with a proviso: What's is optimally maximum for the number of vehicles is down to ability of a control system to stop bunching and optimize transit priority. Why we haven't heard more on this is puzzling, as some huge leaps have been made in developing the software and sensors to make this happen. One of the serious impediments of signal priority for streetcars is the need to co-ordinate the priority for *both directions* at intersections at the same time. The lights might be prioritized to a high degree in one direction, but at the expense of the best algorithm for the streetcars coming the opposite direction. Obviously intersecting vehicular traffic must take a lesser priority than either direction of streetcar, and that may well be the stickiest decision to have to make later.
Absolutely. It's like an expressway that starts on one side of a congested city and ends on the other side, with no connections of equal capacity or speed limit. The Queensway, however, looks pretty inviting to connect the 504 through to instead of going up Roncy. The east end doesn't present a similar option at this time.
Munro specifically addressed that, it is was the optimal confluence of three factors: Time, direction and location. Other data indicated far less gain.
Melbourne has the same problems as well as solutions as Toronto. Some studies indicate Melbourne, as well as hosting some world leading aspects of tram performance, also hosts some of the worst.
Melbourne's trams among slowest in the world - ABC News (Australian ...
www.abc.net.au/news/2017-05-19/melbourne-trams...slowest-in-the-world/8541228
May 18, 2017 - Melbourne's tram services are among the slowest in the world, new figures have revealed. Statistics from the network's operator Yarra Trams shows trams are sluggishly moving around Melbourne at an average speed of only 16 kilometres per hour, with the speed dropping to just 11kph in the CBD.
Melbourne's trams among world's slowest. | SBS Your Language
https://www.sbs.com.au/yourlanguage/.../melbournes-trams-among-worlds-slowest
Nov 24, 2016 - Melbourne's trams were among the slowest in the world with an average speed of just 16 kilometers per hour.
Melbourne trams stopping at red lights putting it among world's slowest
www.heraldsun.com.au/.../melbourne-trams...worlds-slowest/.../fe9bdd856ce0ffffd4af97...
May 18, 2017 - MELBOURNE'S trams spend more time stuck at red lights than trams in any other city in the world. With three-quarters of the city's tram network operating on shared roads, 17 per cent of journeys are spent at red lights compared with the international standard of 2 to 5 per cent. As cars and trams battle for ...
Edit: Enter the title of the last link above into Google to get linked around the paywall. An excerpt:
As Melbourne grows, there is a pressing need to separate trams and traffic.
Transport authorities are looking at smart transport technologies to help ease traffic congestion and deal with a spike in tram usage following the introduction of the city’s free tram zone.
A trial with VicRoads this year will involve installing devices inside trams and traffic signal boxes, to allow approaching trams to maintain a green light.
Yarra Trams spokesman Simon Murphy said trams played a critical role in keeping Melbourne moving and supporting major events.
More than 1000 days of events per year require tram service changes.
“Trams share the city’s roads and traffic congestion is the leading factor affecting tram performance,” Mr Murphy said.
“Which is why we continue to work closely with our on-road partners including VicRoads to find ways to make journey times more reliable.”
A VicRoads trial of part-time tram lane markings on Smith St in Fitzroy improved the average journey time during morning peak by up to 54 seconds.
Daniel Bowen, spokesman for the Public Transport Users Association, said Melbourne’s tram network had great potential to help even more people get around the inner suburbs without driving.
“If frequency, punctuality and reliability can be boosted, so people know the service is a dependable, viable option, more Melburnians will get out of their cars,” Mr Bowen said.
Melbourne has about 170 kilometres of mixed traffic lanes where trams share the road with motor vehicles.
The closest to that is Toronto with 70 kilometres.
Melbourne’s trams carried 204 million passengers in the 12 months to June 2016.
"Daniel Bowen, spokesman for the Public Transport Users Association" runs a blog on Melbourne Trams. Google his name for it.
Just heard a BIZARRE interview on CBC's Here and Now. Gill Deacon interviewed Al Carbone of Kit Kat about his ice sculpture fingers. She asked him if he thought they would help attract customers and he went on and on about some poor woman from the suburbs who got several tickets for driving through on King and then also got a ticket for having no insurance. He stated that 'we" have given Tory an ultimatum and unless things change in next 24 hours there will be something major next week.
Kit Kat appears to have invited Doug Ford to brainstorm ways to undermine the King Street pilot:
https://twitter.com/kitkat_toronto/status/953727350025236480
Apparently Mammolitti was there too.
This could be bad. Just look at this stunt Mammoliti pulled on Finch to make his stupid point, to get an idea:
Toronto city councillor Giorgio Mammoliti believes a light-rail line down the middle of Finch Avenue will routinely back up traffic and destroy businesses. But he felt the need to “do something a little drastic” to bring the point home.
That’s why he arranged for a transport truck to pull a u-turn through the closed-off intersection of Finch Avenue West and Weston Road on Thursday morning. Blocking the intersection at 10:30 a.m., for approximately 15 minutes, led to long lineups of cars in all directions, with drivers honking throughout.
http://nationalpost.com/posted-toro...t-and-weston-road-closed-for-anti-lrt-protest
Being curious... anyone know if there are any restaurants in the pilot area, particularly in or near restaurant row, that are openly supporting the transit pilot?
There was a CBC report about one adjacent to Kit Kat who told Al Carbone to remove one of his icy fingers from in front of their restaurant.
Curious. How many patrons did the Kit Kat Restaurant gain versus lost, because we found out Doug Ford had a meeting there?
See link.
I won't be going there now.
Z-Teca burritos. Have not been there myself yet, but apparently they support the pilot. I've seen posts on Twitter (by other UT members!) about getting "I (streetcar) T.O." buttons there. Also, check out this thread:
https://twitter.com/JasonParis/stat...y|twsrc^android|twgr^copy|twcon^7090|twterm^1
My guess is they were the restaurant that the CBC reference in a recent post refers to...
-Vic
https://twitter.com/JasonParis/status/953715423626874880?ref_src=twcamp^copy|twsrc^android|twgr^copy|twcon^7090|twterm^1
-Vic
Thanks for that @vic ! I was down there again today with dog picking up some hardware at Rotblotts, and walked west through my old neighbourhood to King and west on there. To be honest, the hype factor is way off my scale, and couldn't help every time I saw a Kit Kat sign for the chocolate bar, how the copyright is being abused. No 'nice light snack' for me at King Kit Kat. But I'll make a point of checking out Z-Teca (pronounced "zee" folks...I spent time in San Diego) and when I lived at Peter and Queen, used to go to the basement burrito place west side of Peter, just south of Richmond.
I like it!
-Vic
Nice, and I like Z-Teca, their burritos aren't as crazy over-seasoned and expensive as other places.
