81-717
Active Member
Living in constant fear/paranoia (while physically unharmed) is certainly not desirable, but I don't see how it's worse than having that kind of physical harm actually happen to oneself.Whether you intend that or not, it creates a problem as bad, or worse than the one you actually fear.
To use a specific example, if "incident type x" is 9/11, it's true that no such incident happened in the several decades of commercial aviation before 9/11, but that doesn't mean it's safe to ever go back to pre-9/11 security going forward. In this case, the value of increased security is very much provable.While the value is, even if real, probably unprovable. (incident type x that you worry about does not happen after said unit is deployed for the next 10 years). Wonderful, but the fact that no similar incident has happened in the preceding decade without any such action.........
Though of course there's also the question of, even if incident type x is made essentially impossible, what can be done to prevent anyone out there from coming up with incident type y, z, etc, that are currently unheard of.
