Rainforest
LRT meets the projected ridership. If it was LRT built underground completely with stations the size required to handle 6-car trains similar in capacity to a subway there would be no savings, the cost would be higher than a subway, BUT they are building smaller stations which are NOT capable of handling 6-car subway trains without significant expense and they are running portions of the line at grade which DOES give them significant savings. The fact that they are building stations the size they are with completely low platforms, not the mixed height platforms seen in pre-metro systems like Brussels, tells me there is no real plan to upgrade to subway ever and it is probably just as likely that a Lawrence-Dixon LRT would be built.
If there was significant saving, I would not object to Eglinton LRT.
The problem is that the current cost projection is 6,065 million for the truncated 20-km line, or 303 million / km, even though only 11 of these 20 km are tunneled.
Metrolinx cost projections are in "escalaed dollars" so they take into account inflation. Yet, those 303 million / km are too close to a subway cost, given that the line is to open in 2020 and the bulk of construction expenses should be incurred before that.
At that price, it makes more sense to build subway.
With an Eglinton LRT to subway upgrade the cost of expanding the stations and the disruption of service would likely be unpalatable for a capacity improvement which doesn't significantly improve service when compared to a Lawrence Dixon LRT which not only increases east-west capacity but also serves a new route. When given the option of greater coverage with nearly equivalent service OR less coverage with greater capacity I think greater coverage wins.
Indeed, Lawrence LRT could provide the needed capacity as well as expand the coverage. The problem is at that kind of costs, we'll never see Lawrence LRT.
Note that Lawrence LRT would have to include significant tunneling as well. For sure, 5 km from Bathurst to the eastern boundary of Glendon campus would have to be tunneled; and the portion between Lawrence / Jane and the beginning of Dixon Rd is problematic, too.
