I think there are 3 observations we can take away from rapid transit expansion in Vancouver and Montreal:
  1. Don't over build rapid transit, build only enough to sustain what is required (ie. Canada line and REM using light metro).
  2. Rapid transit should always go into or cross the core, where there is density to support ridership.
  3. Public/private partnerships do work, to ensure 1) and 2) are adhered to, because no one will invest money into money losing infrastructure for the sake of politics.
  1. I’d say the Canada Line is slightly underbuilt.
  2. Too bad Toronto is bordered in the south by Lake Ontario and downtown wasn’t at Yonge and Eglinton, otherwise lots of potential for new lines.
  3. Lease not sell ownership.
The REM is a metro, not a LRT. Even the CDPQ calls it a metro now. Trains are shorter than current Montreal metro trains, but will still be able to carry 600 passengers per train, every 2-3 minutes. It uses the same trains as the Copenhagen metro, and over there they don't call it LRT either.
The media have consistently been calling it an LRT. The Caisse's website calls it a "light rail network" right on the homepage and then again in their "REM in brief" page.
Yes, there is a new, more direct connection planned from the south end of the REM platform at Central Station, to the tunnel linking Place Bonaventure to métro Bonaventure station. It will be much quicker than the current circuitous path.
Excellent! Hmm, though I'm a bit disappointed on the up and down in the connection to Metro Edouard-Montpetit. I wonder if that's what the MUCTC envisioned in the 1970s and early 1980s?
174334
I thought you were trying to argue that it shouldn't be a city asset. Is there any difference any more between Metro and City assets?
Well a city objective is usually against the suburbs' motives.
It's not in French media, the CDPQi even asked the SRC (CBC French equivalent) to call the REM a light metro system and stop calling the REM a "train léger", which is the translation of LRT.
174335
The connection is indeed much more complicated than it should have been. I'm quite sure the original 1970's plan called for a direct connection from the métro platform to the
train station below.
Was curious whether it'd be charged different when the project was announced, but this sounds like it is. Doesn't sound good. Wonder if a similar scenario could play out for Crosstown or Finch LRT over here, e.g charging an extra $0.50 to transfer/ride.
Why it doesn't sound good? The REM price per km includes financing, vehicles, operating costs and construction. And the price per km is still cheaper than a suburban bus or commuter train per user for just operating costs. If anything it shows how inefficient public transit is in general. Usually a province finances a transit project and cheapens it (most LRT projects instead of light metro) because it will not have to fund the operating costs; the cities will.
We were explicitly discussing Toronto's role in the LRT lines. You said that "It was city hall that proposed the initial LRT lines thus city hall shouldn't even be allowed to do such planning in the first place". All the same suburbs that were in Metropolitan Toronto are now in the City of Toronto.
As we are having this discussion in English, I don't see any relevance in what the French media is calling it. The Caisse is very clearly calling it "light rail" and not "metro" or even "light metro" on their own English website.
It seems rather odd and prickly to be coming here and saying that we shouldn't use the same term that the Caisse is using, but instead translating a term being used elsewhere in another language!?!
It was the easiest/cheapest way to build, plus STM operations are not affected, which was a requirement of the latter.
It seems rather odd and prickly to be coming here and saying that we shouldn't use the language that the Caisse is using, but instead translating a term being used elsewhere in another language!?!
Richmond Hill wants a Subway extension, city of Toronto wants a city expension. Studies are paid by the city of Toronto, city of Toronto has thus an influence where a provincial asset should not.
Light metro is LRT but LRT is not Light metro. Both languages are correct but one is more precise. If you want precision you call it a light metro system. Regular usage of LRT in Anglo media is generally a right-of-way system but with crossings. Vancouver calls SkyTrain RRT and not LRT.
The CDPQ/REM's functionning language is French, not English, so I'd trust their French version more than the English one. And in any case, here's an example of a recent communication in English where they use "metro" instead of "light rail"
174336
Will the deeply suburban REM stations have at least half way decent local bus connections?
The STM and RTL bus networks are supposed to be reorganized before the REM opens. The plan is to provide efficient connections to the REM stations, in the same way that almost all bus lines in the central part of the city connect to the métro stations.
The STM has also discussed increasing bus frequencies, with 300 additionnal buses (which will arrive in 2020 and 2021) and a re-deployment of buses currently affected to lines that will become redundant due to the REM. The RTL has also announced that they will adopt a similar approach on the South Shore, i.e. better frequencies across the network and connections to the REM stations.
The Regional Municipality of York has been paying for and leading the extension along Yonge Street into Richmond Hill (and Markham and Vaughan) - not the City of Toronto. Part of the reason that the designis further advanced, and the EA as approved years earlier.
Oh, we could argue that one for years - I'm simply going with the language used on the Caisse's own website - which contradicts comments above that the Caisse wants to call it something other than what their website is calling it!
That "recent" communication also says "light rail" further down the page. There's no indication how old it was - I thought I'd seen that render some time ago ... ah yes, here's the earlier version from a year ago - https://rem.info/en/news/montreal-trudeau-airport. It's kind of irrelevant what term they use on the French version of their website, as we are not having this discussion in French!
A Caisse press release only 2 weeks ago is again calling it "light rail" - https://rem.info/en/news/pivotal-year-south-shore - which is the same term ATM was calling the south-shore line for many years, while calling it metro in French.
Still seems prickly to be objecting to using the term that the Caisse uses currently, prominently, and more often than not. Light Rail is frequently used in English instead of Light Metro - it's far more common. It's also the same term that's generally used in Ontario - even for fully grade-separated lines like the Light Rail in Ottawa.
Whether they call it light rail is irrelevant. Lots of media still call the Skytrain a light rail system. The capacity of the REM will be >25000 ppdph which is a lot more than Eglinton.
Hang on - something isn't adding up. 600 passengers every 2 minutes is only 18,000 passengers an hour. Greater than 25,000 passengers an hour would require a train less than every 85 seconds.
While a peak capacity of 25,000 passengers a day, is starting to cross the line past light rail, 18,000 passengers a day is not.
How long and wide is each car? How many cars per train?
There's been a tendency for private companies to seriously exaggerate the operating capacity of transit cars recently, that don't reflect the reality of Canadian transit operations with passengers in bulky clothing with briefcases, backpacks, or strollers - and sensitive safety devices on doors that you can't lean against without bringing the train to a halt!
They also ignore that a crush capacity for a car might work fine for reporting the capacity of a line with infrequent service (such as every 10 to 15 minutes like that proposed for the Kitchener LRT, or the late-night service on the Montreal Metro) but it doesn't work when you are trying to get a vehicle through a stop every 90 to 120 seconds, as the crush conditions significantly increase the dwell time, reducing capacity on the line!
