denfromoakvillemilton
A few questions for Joseph:
1) Was there any consideration given to re-activating the rail corridor (now a rail trail) from Bells Corners to Stittsville, and potentially on to Carleton Place? That west-southwest quadrant seems to be the only part of the NCR that isn't being served by either Moose, the O-Train, or Rapibus. I acknowledge that by and large Moose is using active rail corridors (or at least corridors where the rail is still in place), but it would be a worthwhile addition, if the right political conditions were in place.
2) Are there any plans for a future infill station at Woodroffe along the red/green interlined route? That location would make for a pretty decent transit hub if the Confederation Line is ever extended one (or two, depending on spacing) stations further south. You'd have 2 Moose lines, LRT, and BRT at that location.
3) Curious as to why Dunrobin wasn't included as a station.
4) Based on the map on your website, it doesn't look like the Green line goes to Bayview. Does it?
I'm also going to take a shot at creating a map of Moose overlaid on top of OC Transpo & STO rapid transit, because I think showing how Moose "fills in the gaps" could be pretty interesting to see.
And also, glad to see that Moose is reaching out on forums like this to answer questions!
Thanks for your questions.
Q1) Was there any consideration given to re-activating the rail corridor (now a rail trail) from Bells Corners to Stittsville, and potentially on to Carleton Place? That west-southwest quadrant seems to be the only part of the NCR that isn't being served by either Moose, the O-Train, or Rapibus. I acknowledge that by and large Moose is using active rail corridors (or at least corridors where the rail is still in place), but it would be a worthwhile addition, if the right political conditions were in place.
A1) Moose Consortium must focus first on getting the core 400 km system operational. Many additional lines become financially viable under the PPR model once the core system is assured. Some of those would be Moose Consortium operations, but they could also be autonomous complementary services, whether private regional bus services, VirtuCar, a boutique stream train service for tourists, etc. Another two examples of a short line that become finacially viable once we've got the main line running are the lines to Buckingham, QC, and Aylmer QC.
Q2) Are there any plans for a future infill station at Woodroffe along the red/green interlined route? That location would make for a pretty decent transit hub if the Confederation Line is ever extended one (or two, depending on spacing) stations further south. You'd have 2 Moose lines, LRT, and BRT at that location.
A2) You're correct -- but let me explain how such a consideration fits into our business concept. For the most part Moose Consortium won't be unilaterally determining exactly where the stations will go. Ours is an "open market development model" for "Linked Localities". That will be an open and, we expect, a highly competitive market. But as you note, there are some logical locations where our entire system would benefit by making pro-active arrangements for a station. Such stations can be justified in the PPR because their existence would raise the financial value of all the other stations by at least as much as could have hypothetically been raised on the 0.8 km radius model. We've not yet gone through that process, but we have, for example, asked the NCC to let us know where they would ideally want a station for Gatineau Park. Also, it's obvious we'd want a station at the UQO campus on Taché Blvd at the north end of the Prince of Wales Bridge.
Q3) Curious as to why Dunrobin wasn't included as a station.
A3) Essentially all locations along the existing corridors could have "Linked Localities" -- those labels on the map are for general geographical orientation only. Other than the exceptions mentioned above, the only stations to get train service from Moose Consortim at those that pay the formula-base train-stopping fee. And in the Greater National Capital Region, we won't go beyond about 50 stations. Too many stations slows down the service. Please see the full PPR whitepaper: https://www.letsgomoose.ca/wp-conte...sePropertyPoweredRailModel_2016-06-28_PDF.pdf
Q4) Based on the map on your website, it doesn't look like the Green line goes to Bayview. Does it?
A4) Correct, but there will be more than one station at which to transfer, and we will ensure scheduling that makes the timing of priority transfers efficient for passengers.
Q5) I'm also going to take a shot at creating a map of Moose overlaid on top of OC Transpo & STO rapid transit, because I think showing how Moose "fills in the gaps" could be pretty interesting to see.
A5) That will be useful, thanks. But keep in mind that whereas tracks don't move easily, bus route do. We'll be doing our detailed modeling with MATSim http://matsim.org/ Recently I was in Vancouver and noticed that the SkyTrain's lines, "outstretched fingers" like MOOSE's plan on existing rail, could do with some better webbing between those fingers. Once MOOSE rail is operational, municipal bus services can be expected to logically adapt, because the existing fleet and crew of drivers would get a lot more use filling in the areas of those triangles than running long-haul that's being served by train. From the business point of view, Moose Consortium is structured to have all sorts of alliances with ancillary services, public and private sector.
RE: And also, glad to see that Moose is reaching out on forums like this to answer questions!
"Thanks and a tip'o the hat" to the participants on this forum.
Joseph Potvin
Director General | Directeur général
Moose Consortium (Mobility Ottawa-Outaouais: Systems & Enterprises) | www.letsgomoose.com
Consortium Moose (Mobilité Outaouais-Ottawa: Systèmes & Enterprises) | www.onyvamoose.com
joseph.potvin@letsgomoose.com
joseph.potvin@onyvamoose.com
Thanks Joseph! Very glad to see that there was indeed a rationale behind the decisions, as opposed to being oversights. It's nice to see transit planning that is based in evidence-based decision-making, instead of decision-based evidence-making.
And with regards to the map, I was only going to include BRT services that had fixed infrastructure (i.e. a Transitway) associated with them. I agree that including local bus routes would be rather difficult to pin down, not to mention be visually distracting.
I'll be looking forward to seeing more details on how the central segment of the Trillium Line will work with all of those services overlapping on it, and what type of upgrades will be necessary to support it (beyond what is being done in Phase II of the TMP).
Great. You'll notice that Moose Consortium documents are under CC-by 4.0 licensing. If you do the same others can readily adapt the work.
Joseph Potvin
Joeseph and Peter, great work!
One question though, will this be a rush hour, or all day service type thing? Thanks in advance!
