micheal_can
I got a better, irrefutable argument: My tax dollars are going to pay for this and I will not be silenced about a new airport being built when one is underutilized.
Argue that!
Argue that!
Oh come on, that one is easy! Accept an all private money proposal instead of doing a P3 RFP and let’s get going!I got a better, irrefutable argument: My tax dollars are going to pay for this and I will not be silenced about a new airport being built when one is underutilized.
Argue that!
As much as I am a fan of electric aircraft developments —HFR ( high frequency Rail) is not direct competition , airports and rail support each other nicely if properly designed. But an airport is much cheaper to build and can be run at a profit.
Considering HSR ( high speed rail) as an long distance alternative just doesn’t work. A high speed rail line will chew up thousands of acres of class 1 farmland ( more than the airport), divide communities, cost 10x as much, provide service to 1/100 the destinations , never break even, and be obsolete before it opens thanks to this:
Isn't one of the drawbacks of the Pickering Airport its distance from large corporate head offices and Fortune 500 satellite offices? Compared to Peel, Durham has a much, much smaller corporate footprint.
What a terrible reach even for a Pickering airport shill. The majority of an airport's heat island is caused by the airport itself! What would happen if we paved acres of land for a Pickering airport? It would become a heat island due to all that ashphalt absorbing and reflecting heat. Good grief.Welcome to the Dog days of summer! Toronto’s hottest month of the year is August, and this year could be a record breaker. Pilots worrying about density altitude and safety can hopefully soon look forward to the smart design and heat island reducing location of the new Pickering airport.
Pickering Airport’s Heat Island Advantage - Friends of Pickering Airport
Print 🖨 PDF 📄 eBook 📱Toronto Pearson International Airport is measurably hotter than the surrounding area because of something called the “Heat Island Effect”. Pearson Airport was clearly not designed to consider the heat island effect. It is surrounded by urbanized areas, with less-than-ideal...pickeringairport.org
I expect better of you Mark.
All true, but it’s a chicken and the egg issue, which one comes first?Isn't one of the drawbacks of the Pickering Airport its distance from large corporate head offices and Fortune 500 satellite offices? Compared to Peel, Durham has a much, much smaller corporate footprint.
Challenge his lies and you get blocked!
I hope more folks push back.
You are clearly being rude and mocking Mark in many of your replies. Offending others is your passion, I get it. No need to ask more people to push back and erase fair and honest opinions.
