Dan416
I like their plan for fixing up the arterial road network.
...Finally, it's time for there to be a ring road around London, ON
...I'd like to see more simple dual carriageways with at-grade intersections, interchanges where necessary, common in the US (see US 61/State 27 through Missouri and Iowa as a great example). In Ontario, we go big (full freeway) or not at all. Examples where simple twinning makes sense:
Ever driven on the Veteran's Memorial Parkway (VMP) in London? Its an "expressway" that has intersections instead of interchanges. It was a 2 lane road from the 1960s until most of it was twinned in 2006.
If a ring road ever gets built around London, the VMP would mark the eastern edge, an extened 403 will make up the north section, and a new freeway is needed to make the west segment. The 401 and 402 would be the southern part.
The only highway we have now is the 4 which just takes over city streets to designate it as highway 4.
I've always found it odd that Highway 4 is in London and Highway 404 is in the GTA. Aren't the numbers of the 400-Series supposed to reflect the highway nearby? (Ie 402, 403, 406, 407, (408 if built), 409?, 410, 416, 417, 427 all have numbers to reflect the nearby highway.)
But I don't think it's substandard. Most European highways would be substandard if you compare to our highways, but maybe we should look at it another way - it's not their highways that are substandard, it's our highways that are overbuilt. Think of how much money we'd save if we built like the Italians do:
Italian autostrade vs. Canadian freeway
The Canadian one is probably triple the width. And the fact that we build to the same standard through the Canadian Shield makes our highways way more expensive than they need to be. There are some ridiculously wide rock cuts in Ontario.
That only came later. Initially they were just numbered starting from 0, IIRC (400, 401, 402, 403, 404).
posted this on SSP.... I really think they should be considering the 2+1 style road like Sweden has for some of the more remote sections in Ontario. 2 lanes plus 1 lane that alternates every few KM, cable barrier, some interchanges, some at-grade/RIRO... it`s led to motorway level safety but with much cheaper costs (as it is basically using existing corridors/roadways).
The focus of road expansion in the GTA should be eliminating bottlenecks and dead ends, not the construction of brand new highways. Adding a third lane to the southbound DVP over the 401 comes to mind. Adjusting lane configurations would go a long way at places such as Avenue/Davisville, and in the Dupont/Davenport and Black Creek/Weston areas. Traffic could be relieved from arterial roads by building more connections across barriers such as the 401 and various rail lines.
Most of these projects involve nothing more than repainting lane stripes and building 100m road segments across gaps. Anything larger should be built only after transit has been given a chance.
