The question is; what would you rather have, 10% less transit employees and a DRL by 2030 or double the number of transit employees and the DRL by 2030
The other question is, would you rather spend $50B for the the Big Move or $52B for the Big Move with some enhancements to satisfy the wants of a large segment of the public.
Btw, if the area barely supports buses, then the transit planners and leaders of the previous regime must have been pretty stupid to prioritize LRT over a DRL subway.
Well if you want to create strawmen - yeah sure, if it could be proven that the same amount of work can be done for less, then fine (props to privatized Garbage Collection). The point I was illustrating is that city-building should really come before small increases in efficiency if it means the city is less productive or develops slower as a result of those perceived efficiencies.
I worked on a couple of KIP-funded projects, which was the Province's way of stimulating the economy in 2009. Basically, every project was fast-tracked and done as a design/build - it's inefficient in some way but projects are built twice as fast as they usually would because you throw everyone onto it at once. In general I'm not usually in favour of that model because it involves a lot of compromise, but in the end I was amazed at how fast things got built. I decided at that point that sometimes inefficiency is worth it when
problems have to be solved immediately and you need things built quickly. If we lose $6b in productivity each year because of a traffic clusterfuck, then throwing $6b in capital at the problem (in the form of more labour on the policy side and fast-tracked construction) is money that is very well spent - despite the optics.
For your other strawman arguement, give me the details of your proposed $2b increase and I'll give you my opinion. I don't think it matters though, because that's not the point of this discussion. My point is that "cutting waste" has to be evaluated in a long-term cost/benefit respect not just a "it looks like we should do this so let's do it" way.
Regarding your last point, it was an exaggeration for the sake of point-making. I'll leave it to you to go look at the multitude of financial cases that have been made against building subways where there is no need, and how the Scarborough RT has been shown to lose millions every year because it is vastly underused. The ridership projected for it when it was built failed to materialize, and current ridership levels would need to
more than triple in order to make the extension viable. Has Ford undertaken to do a cost/benefit analysis for his proposed lines? What about his policy - other than "people want subways" -
has assured you that it would a wise way to spend taxpayers' money?
Once again -
we all want subways. But unless a financial case can be made to build them,
how can people who are so dead-set against "waste" at City Hall be so much in support of a subway plan that Ford has yet to show the feasibility of? Do you just
ignore every report that says "Hey, actually we can't afford to keep that subway running so maybe we shouldn't build it" or "Yeah, um, subways are great and all but they just aren't financially sustainable in certain parts of town"? Do you see what I'm getting at? Again -
what has Ford said or done that makes subways everywhere a sound financial decision?
