L23
Active Member
i suspect their "anonymous source" is JW.
Me too.
Surely the competent Toronto Police Service knows where their star suspect is.
Yoohoo Jimmy! What's your thoughts?
I can't for a second believe that the dim-looking M D Ford could lose surveillance with the 'stang and RoFo in it fleeing. As long as they knew which plane he (allegedly) was on, they would be able to figure out the final destination, be it Hamilton or elsewhere. Once the plane landed, surely the TPS could have local authorities keep tabs on RoFo, RIGHT??? He is still the subject of an investigation, isn't he? I can only imagine if they let him slip away, only to retire to Cuba, hosting a hit Reality Television Program for the rest of his days.
The Toronto Sun is reporting that he may be at Homewood in Guelph. I was thinking that would be a possibility. It's supposed to be an excellent facility.
I just saw the CP24 clip - he delivered the line without any bluster - I'm leaning towards the fact that he might not be lying based on how he mentioned confidentiality of those in the program - this sounds like something the program would have warned him against violating.
Homewood seems likely - Ford can pay for a fuller program and I'm pretty sure he's not using the EAP.
http://www.torontosun.com/2014/05/06/is-rob-ford-at-guelph-rehab-facility
Notice the use of anonymous sources................. One day I would like to make these asshats apologize for their hypocrisy. Anonymous forces weren't good enough when it was the Star (which of course were proven to be correct) but when it comes to the lying liars Ford and their mouthpiece Joe Warmington, anonymous sources are A-Okay. F them.
From Twitter:
Tony Smyth @LateNightCam 2h
Reports that Rob Ford withdrew his application to enter the USA. This is usually the option given rather than detention when denied entry.
Based on what I have seen and heard, I would say Bellwood is more "upscale" than Homewood.
If they had stopped to switch him into Mikey's car that delay surely would only have made him easier to follow. (And BTW it is a Camaro.)
None of the rehab facilities I'm familiar with would a) have Ford working out already or b) have him chatting with his toxic family already.
There is at the larger airports, when I moved from the UK to the US I had to go through US immigration in the airport before I got to enter the waiting area for the flight.
The other point you make however (RoFo didn't need an esta as a Canadian visitor) is correct though - I don't think you need a visa waiver if you're Canadian entering the US, do you?
Thanks again.
He would only need a visa (there is no concept of a visa waiver, so far as I know) in order to reside in the US beyond the visitor limit (e.g., when someone goes to school in the US) or to work in the US on more than a very short-term basis. The FTA, then the NAFTA, has made it much easier for Canadians to work in the US, but there are still some requirements (as there still are vice versa).
There is a waiver concept, for someone who has been refused entry. (What is being reported is that Ford was given the equivalent of a chance to accept a warning and withdraw rather have a ticket issued; it seems to be a fairly common practice to give someone one shot at just going away rather than being refused entry.) If refused you can apply for a so-called waiver. It is discretionary, and, I gather, can take up to a year to get (if at all), but if you do get one then you can answer that, yes, you have been refused entry in the past, but still enter by virtue of the waiver. A waiver expires, so has to be applied for anew, every five years.
Unless they've changed location, Bellwoods is located in a pretty dreary business park and shares space with a nursing home up at Vic Park and McNicoll. Maybe their program's better (? no idea?) but Homewood's campus does look gorgeous - a little more soothing than BW.
Bellwood:
http://www.tendercare.ca/contact.html
