Second_in_pie
I'm assuming you broke the lines up based on different construction techniques?I posted this in the group forum but I'll post it here too. These are the breakdowns for distances of the proposed subway lines. I have broken some of the lines up into different sub-sections because a significant change in construction techniques could occur (ex: tunnelled to trenched). These distances are approximate, but follow the proposed routes of the lines. Station costs will also need to be added in later.
I can see with Eglinton that it'll be tunneled from Jane to Laird, where it'll go above ground to Don Mills? I won't argue with that. Some wonky bridging/tunneling from Jane to Royal York, then Richview trench to Martin Grove. After that, raised guideway along 427/Dixon Road?
I also thought that Kipling-Sherway would be relatively easy to do with an easy raised guideway. A bit of the route back to Dundas could probably be done with the same.
I might add in a DRL North on Don Mills to the equation. Don Mills-Sheppard is about 6.1 kilometers, and Sheppard-Finch is a good 2.1 km, 2.8 if you want to put a stop right at the heart of Seneca College on the Finch Hydro Corridor. I'd imagine that the Eglinton-Sheppard portion could be done pretty much all raised guideway along the centre of the street, but above Sheppard, I'm not sure how well it would work. So I'd probably duck the subway underground before Sheppard, probably just after the 401. With that, the raised section would be about 5.4 km, and a tunnel to Finch would be 2.7 km (3.4 to the Hydro Corridor)
