Cobra
And Scarborough happens to be rich in votes
So what exactly has happened?Please. Tory will get what he wants here. The subways will be low ridership, and the LRT will be better. But this is called buying Scarborough's silence. They should approve both and move because this is never going away.
... this should work to counteract Wynne's low poll numbers.
Their moving for a motion to study. Wynne will need the GTA to pull out a win, so this with RER should be good. Brampton GO service next summer too. This is a power play and it will be sucessful imoI disagree with that actually. I think another major TTC project funded mostly by the province would drop her approval ratings even further. One of the primary criticisms of her leadership has been that it is Toronto centric; the others have been lack of execution on promised change, and not reigning in spending.
I don't even see the problems with conversion. The station platforms are long enough you can upgrade half the platform at a time.It blows my mind that not one single politician or major transit advocate (like Steve Munro) has endorsed conversion of the Sheppard Subway. They must really want SRT debate round two.
That's ($600M) the conversion to LRT cost (maybe in 2006$), where the trains are taller. I have not seen a cost associated with conversion to SkyTrain. Those cars are not as tall and the conversion cost is likely minimal.
Estimate by the TTC was $600 million. I don't think that took into account the clearance issues that were later brought up, though.
Order an LRT vehicle that is shorter and has a foldable pantograph.Tunnel height is the problem. Not sure what kind of expense we'd be looking at to rectify that issue. Likely in the billions of dollars.
That's too bad then. That's the only way to keep cost down. Other cities, the subways are outside.It should be easier to convert the subway to SkyTrain, or to another type of mini-metro with conventional motive power, as long as they are all high-floor.
But, an elevated line between Don Mills and Kennedy will not be popular with the locals. A lot of resistance can be expected.
