 6.4K     0
I predict approx 150-meter-league EMUs for Bramalea-Unionville GO RER.
Large number of infill stations + existence of UPX train in corridor + corridor efficiency + it's cheaper to share track than build new track + tighter slotting between UPX trains + difficult to squeeze tight headways for all future services in Georgetown without matching train performance envelopes = I predict high performance 150-meter EMU's for the GO RER Bramalea-Unionville (SmartTrack endpoints), with performance profiles that cleanly overlaps the performance profile of UPX EMUs, since it's extremely hard to slot the 12-car bilevels between fast & fast-accelerating UPX trains, but you can pull it off using high-performance France-style EMUs -- possibly two, or more of those, slotted between 15-minute UPX trains, depending on corridor and signalling optimizations, and whatever time-padding might be required for the extra stops GO RER (short dwell + fast acceleration) makes over UPX.
-- Station savings by using shorter platforms when building many of the infill stations (more than half of the 22).
-- Potential trainset savings by using shorter (but near-subway-frequent) trains for allstops
-- Uusing 12-car GOtrains as limited expresses and peak overflow.
-- If high platforms are chosen (i.e. limited EMU choice), only 7 existing GOtrain stations need conversion (plus a platform or two at Union).
If we recycle Weston/Bloor UPX platforms (turning these high-platform UPX terminals into bona-fide RER terminals, then potentially 5 stations need full conversion, with 2 needing simple platform lengthening, and these specific stations retain ability to interchange between limited-stop 12-car low-floor GO train exresses and the high-floor GO RER Bramalea-Stoufville.
I have family from Hong Kong, but really Smarttrack or GO RER is pretty much what the East Rail Line in Hong Kong is like:
http://en.wikipedia.org/wiki/East_Rail_Line
It used to be primarily a single track that got expanded and also electrified over the years, and now they pretty much run subway style trains.
I should be the last one to say it! But that seems a bit harsh.
There is not much point in starting an EA for new stations until electrification is a done deal, and until the vehicle choice has been made. For example, if the system will continue to run on 12 car bilevels, then (GO says) a Kitchener line station at Liberty or King is impossible.
Plus, the sooner you announce your station locations, the sooner you start the lobbying efforts for or against those choices. Witness Leslie and Eglinton.
Still, I'm glad that Tory has rebranded this and forced the planners to think about Toronto's needs, and out here in the daylight instead of behind closed doors. We all should be.
Agreed, but I think that the decision for the vehicle choice should be made on the decision to have these stations, not the other way around.
We need these stations downtown badly.
You design transit around peak usage. We already have an idea what the peak usage will look like because the GO trains are peak only, so lets take a look.
CurrentlyRidership per weekdayTotal Train trips a dayTrips AM peak (6:30am - 9:30 am)People per train (am)People per train (pm)
Stouffville 15,000 (7,500 each way)15 ( 7-am, 8-pm)77,500/7 = 1,0717,500/8 = 938
Kitchener18,000 (9,000 each way)16 (9-am, 7-pm)99,000/9 = 1,0009,000/7 = 1,286
After RER
Stouffville 15,000 (7,500 each way)72 (18 hours x 4)127,500/12 = 625625
Kitchener18,000 (9,000 each way)72 (18 hours x 4)129,000/12 = 750750
Source PDF for the current ridership page 16 and 19
Bombardier BiLevel Coachs per TrainTOTAL BiLevel Coachs Needed for AM ALP-46 NeededNippon Sharyo EMU per TrainTOTAL Nippon Sharyo EMU Needed
Stouffville625/132 = 55 x 12 = 5612625/79 = 88 x 12 = 96
Kitchener750/132 = 66 x 12 = 6712750/79 = 1010 x 12 = 120
Total12324216
Cost$423,054,335.82
($3,435,714 x 123)
$234,058,981.92
($9,752,457.58 x 24)
$1,095,401,618.64
($5,071,303.79 x 216)
Bombardier BiLevel and ALP-46 = $657,113,317.74
Nippon Sharyo EMU = $1,095,401,618.64
Single level EMU's do not make economic scene for GO. They do not help with Union station problems. Yes they reduce dwell times but because you need more trains during peak hours, you are causing problems at the station throat (running lines divide into platform tracks). If you run smaller Bombardier BiLevel Coach trains (6 coach + train) then you can fit two per station track, double birthing without causing station throat problems and helping to lower the dwell times by having two trains dwell on one track.
So the next question is what about bilevel EMU's? They should work from a ridership perceptive so lets take a closer look. There are no bilevel EMU's on the market that are FRA compliant. So in order to use them GO would need either a FRA waiver or to make a bilevel EMU FRA compliant. I don't think Transport Canada will give GO a FRA waiver. We can argue about this until we are blue in the face but none of us know what Transport Canada will do. How much would a bilevel EMU that is FRA compliant cost? I have no idea.
1 ALP-46 + 6 Bombardier BiLevel Coach = CAD$30,366,741.58
By total length:
CAD$30,366,741.58 / 7 = CAD$4,338,105.94
By passenger usable area:
CAD$30,366,741.58 / 6 = CAD$5,061,123.59
Each unit of a bilevel EMU needs a cost between CAD$4,338,105.94 and CAD$5,061,123.59 otherwise sticking with the Bombardier BiLevel makes more sense. A hypothetical Nippon Sharyo EMU cost is CAD$5,071,303.79. I don't see how a bigger unit will cost about the same.
- tight spacing of GO RER stops (if this SmartTrack element is kept) is inefficient even with electric locomotives; need EMUs;
I agree with you that EMU would be better for stouffville (7 new stops), which is why GO trains wont be stopping at smartTrack stops.
- Multiple research papers show high platforms DO shorten dwell times. France uses short subway-style dwell times with their lines using high-platform EMU RER trains (both single and double deck).
I can't read french so i can't figure out what the french system is like. GO has 213,000 daily train ridership with 91% of them using Union Station. Do any of the double decker EMU lines have 91% of their ridership getting off at one station?
-If EMU forces platform height change, ONLY SEVEN pre-existing GO stations (plus a platform or two at Union) require platform height upgrades.
If i'm wrong and GO does get a FRA waiver those bilevel EMUs are the same platform level as GOs current feet so the platform height will stay the same.
-better ability to tightly slot many similiar-service trains between UPX trains (e.g. EMU behind EMU);
How close they run together depends on the breaking power of the trains and how much those trains weight. It's true that single level trains would weight less than bilevel trains of the same length. If the single level trains need to be longer to carry the same amount of people, i'm not sure the difference would be that great.
TypeWeightTo carry 750 people
Nippon Sharyo DMU148,000 lb (67,132 kg)750 / 79 = 1010 x 67,132kg = 671,320kg
Bi-Level Coach110,000 lb (50,000 kg)750 / 134 = 66 x 50,000kg = 300,000kg
ALP-46202,822 lb (91,999 kg)11 x 91,999kg
google doc source of the weight of the Nippon Sharyo DMU page 24
391,999kg (ALP-46 + 6 Bi-Level Coach)
671,320kg (10 Nippon Sharyo DMU)
Now this is using the Nippon Sharyo DMU weight, i have no idea what an EMU version would weight, it would be less though. How much less, I have no idea.
- may not be able to reliably run Barrie/Kitchener/UPX/expresses concurrently in _both_ directions at high-frequencies.
Between Weston and the diamond = 4 tracks
South of the diamond to bloor = 6 tracks
Once barrie joins, it becomes 8 tracks
I think there is enough tracks to carry all the RER trains down to Bathurst Street for a while to come. The problem is between Bathurst and Union Station, the station throat, but you can't solve that problem by running singel level EMUs at it. It has to be bilevels with double birthing.
Maybe I'm reading too much into your post, but it seems we now agree that UPX should be evolved into a true intra-urban RER/SmartTrack/S-Bahn/whatever. OK maybe with a small premium if you choose Airport branch instead of Bramalea branch.
But, let's give Metrolinx a little time to catch up to us, before they need to start the station EAs :)
Personally I think SmartTrack will just be rolled into GO RER for the Kitchener and Stouffville line with a few more stations and better fare integration. Basically it will be a combination of the 15 minute electrified service from Bramela to Unionville, with additional stops as illustrated in SmartTrack plus maybe 1 additional one at Woodbine Race Track if they do expand the casino. I believe Tory will leave the airport spur alone if it does cost $4-5 billion. He doesn't want to raise taxes, and even if he finds the money, he will probably use it on more pressing projects like the DRL or Gardinener.
The extra station at Mt Dennis and St Clair should be possible but the Liberty Village stop wont have enough space for a station i don't think. On the stouffville part, there are a lot more stops and im not sure what happens to travel times with that many new stops. It may make the current users of that GO line unhappy with all the extra stopping.
SmartTrack provides little to almost no relief of Yonge-University and particular Yonge-Bloor. It's moving people from too far east, to to far south. Most people boarding the subway at Kennedy station are not heading to Union Station.
I agree with you which is why the DLR should come before Smart Track. At $5.2 billion cost left over for smart track, the city will be paying at least $2.6 Billion.
Vaughan extension 8.6 km / $2.78 billion = $323,255,813 a km
If you were to run the DLR under queen, then up to pape station that would be 5.69km.
DLR 5.69km x $323,255,813 = 1,839,325,575.97
It's likely even more than that, but it's looking cheaper than the citys part of smart track.
With longer trains and station modification, yes - it could be a good rapid transit option. However, I doubt Metrolinx will touch UPX, and instead slot a different EMU service between the UPX trains. Metrolinx will want to use the profitable UPX as an excuse to get a green light on high speed GO trains, and the only way UPX will be replaced is when it's replaced by the future London-Kitchener-Pearson-Union GO HSR train, probably about 20-30 years from now. Until then, UPX will probably operate as a sacred cow to Metrolinx, with profits justfying its continued operation (Metrolinx's probable opinion, not mine).
The faster acceleration of EMUs plus the shorter dwell times (e.g. 30-45 seconds instead of 2 minutes) at stations other than Union, compensates for the extra stations.
Also, with frequent trains every 5-15min, there is no reason to dwell to a precision schedule anymore, and keeping trains moving becomes the priority, even leaving 1 minute early or late to make sure the train is efficiently slotted in its headway rather than sticking to its precision schedule. Positive Train Control (which Metrolinx is doing feasibility evaluation and may be introduced with electrification) would also simplify ability to do short headways, both from a regulatory perspective and operations perspective. Even with the extra stations, the station spacing is still less dense than the subway. All of these have shown in studies of other commuter-trains-becoming-subway-like systems of other cities (Europe and Asia precedents). Metrolinx also has this information; that schedule precision stops being important at 15-mins-and-more-frequent, and short dwell becomes more important; that it's more important to keep trains continuously moving. For this reason, triple the number of stops using EMUs, can potentially take less time than fewer number of stops using current 12-car bilevels, and it also becomes practical to run very tight headways if corridor allows (e.g. contention with other services, including crossovers).
Chop the Eglinton spur (most of $5.2bn) as I predict what might happen, and the mathematics become different. The city essentially only need to pay for accelerated introduction of infill stations. This is a small fraction of $5.2bn.
In theory, you could unify UPX into SmartTrack, and send every other trains down the airport branch. 7.5 min service south of Pearson, and 15 min service to Pearson / to Bramalea. But I doubt they would turnover the UPX infrastructure in less than 15-20 years.
If there's ONE thing that I agree would make UPX go extinct -- it's the presumed GO high speed rail service (Ontario's now-rail-happy government, in all the GO transit expansions, and the current in-progress new HSR feasiblity study making it a possible de-facto Metrolinx service, and the mention of a "Pearson" high speed rail station). At least not before GO HSR Pearson stop -- presumably a theoretical Woodbine Racetrack station and a LINK train extended to Woodbine over the old UPX spur, with a LINK train replacement that services all Pearson terminals with 3-to-4-minute frequency service). The current UPX service is too optimized to Pearson to be converted anytime soon (baggage racks, short trains, short platforms, airport arrival boards, airport checkins at Union, etc) so they will likely profitably milk that pre-existing infrastructure for many years, before replacing with a forecast-profitable GO RER High-Speed Rail (Kitchener GO RER II sequel, 2030-2040+) London-Kitchener-Pearson-Union. Weston/Bloor would become plain RER/SmartTrack/surfacesubway/whatever stations, and they would instead go to Woodbine in order to transfer to the "new LINK" faster & automated airport terminal-transferring train extended to Woodbine Racetrack over the now-old UPX spur.
Don't worry about it. He's got a clear bias and my statement went against it.
You are right that EAs come after a ton of discussion, including who's going to pay for the EA. There's also absolutely no point in doing them in advance because they don't age well; either you go to construction or you effectively start from zero as updating an EA is nearly the same price.
Anyway, if Rob wants he can be right about this. GO has never considered any additional 416 service prior to SmartTrack being proposed, not even a stop at Downsview.
Challenge is what GO staff (now Metrolinx) planned and what they got funding for are 2 very different things.
I don't see how ST could work using anything but the UPX line. The GO lines will become increasingly clogged as RER comes on line and it is nearly impossible to have a non-stop GO train from Bramalea to Union where they will not eventually "catch up" on the ST train and have to follow it into the city.
The very logical thing to do is get rid of the UPX and turn it immediately over to ST but that would save too much time, money, and aggravation for Metrolinx. What they can do it is run every other train as UPX and one as ST but closely scheduled....ie, have a UPX leave Union and a ST less than a minute later. This would mean the ST train would have a 14 minute head start on the next UPX so it would never catch it and hence have to slow down waiting for the ST to get out of its way.
It is not impossible. A short dwell, (possibly high platform), fast accelerating EMU can slot between UPX trains, with a few mins padding for the additional stops, keeping a passing track free for limited stop expresses. Alternatively, the UPX EMU and limited stop expresses use the faster track and the allstops/SmartTrack use the slower track. There is a pair in each direction, and separate tracks for Milton/Barrie (once Bloor gets six tracks through, as shown in Google Maps) to only need to worry about an express-allstop pair of tracks for UPX and Bramalea GO RER (modified SmartTrack) with ECLRT taking over Eglinton spur. If Eglinton spur built, send half up to Bramalea and every other train down Eglinton. Short headways are possible with improved operations. It can be done.
Also, this is why I think EMUs will happen on the Kitchener corridor for the allstops.
I sense your sarcasm, but you are still missing my point by speaking and thinking in absolutes.
GO/Metrolinx have considered stops at Downsview, St.Clair, Mt.Dennis, Caledonia, Bathurst North.
They did not consider stops at Gerrard, Queen, Unliever, Liberty Village, Lawrence East, Ellesmere, Finch, Milliken, 14th Street, etc and I believe these are all very important as well for the 416, especially downtown.
Funding for any additional stations should come from the city as well as any federal funding we can possibly get.
I understand that we have very little idea what Metrolinx staff have and have not considered on an official level due to the huge number of off-camera meetings at the board level and a general gag order.
I also know SmartTrack is almost entirely a concept that Tory got fed from his campaign staff which is largely Liberal with a side of Conservative.
We also know that at every opportunity both Metrolinx staff and consultants have pushed for tighter integration with TTC; DRL West to Exhibition is an excellent example of that.
To say it wouldn't have happened without Tory is extremely short-sighted. Yes, there aren't a lot of political points to be won, but both sides from an engineering perspective are entirely in favour of it. Politically, Ford killed the idea that TTC could make the province look good (a gamble taken in co-operation with Miller), so Wynne is also going to be in favour of continuing to win 416 seats by improving transit in the 416 WITHOUT TTC involvement.
I believe your assertion that Tory is the saviour of GO 416 service to be highly questionable. Personally, I think Tory is being worked like a marionette to reduce the provinces cash requirements. Many of the stations you mention are quite useful to all GO riders, not just those in the 416. Tory's going to cover some of the cost of the 416 allotment which frees up money so the province can invest-in and win additional seats in 905; and we're going to love and re-elect Tory for doing it. Frankly, after getting Eglinton and Finch from the province we can afford to kick in some money, but I bet if the election turned out differently many additional 416 stops would happen anyway even without a Toronto contribution. Wynne, having been accused of being Toronto centric, has a strong interest in someone else demanding for more 416 money.
It also proves beyond any doubt that public transparency within Metrolinx is a bad thing politically. What Metrolinx staff mention as possible and wanted at meetings off-record is much broader than the public official documents imply.
All that said, it's okay to be played for fools in this case. I don't have any issues with either Wynne or Tory being re-elected, or Toronto kicking in funds. The public view of politics, what happens behind the scenes, and the truth are 3 very different things.
To say or even suggest that it would without any hard evidence would be even more foolish.
All I can go on is the facts that I know, and what I have been given the knowledge of is that while many studies like NEPTIS foundation, I-E-Metro and CityRail have proposed this idea, John Tory was the first politician to actually bring it to the attention of city council, the province and attempt to make it happen.
Sure, Metrolinx might have had this idea, they also could have been working on alien ufo technology and teleportation. I don't know.
The fact of the matter is that they didn't attempt to build these stations downtown or show any plan to, and thats all that matters to me.
I do not think Tory is some saviour, he has plenty of flaws. But give him some credit where credit is due.
+1
He's certainly lubricating the GO RER concept far better than previous mayors, and making it easier for Ontario to deploy GO RER. I do expect that the Eglinton spur (which would consume essentially half the whole cost of SmartTrack) gets chopped, but that the infill station idea gets kept and funded. With the huge savings by chopping the Eg spur (and extend ECLRT instead), the city and feds won't need to fund nearly as much for the infills.
Regardless of who came up with it (Tory or Metrolinx), and regardless of brand name (SmartTrack or GO RER), most of the ideas coming up regarding turning a GO corridor into a rapid transit corridor, is a pretty sound idea in principle.
Regarding squeezing UPX trains along with SmartTrack trains (or, if you prefer, call it GO RER with extra infill stations)...
People keep saying Georgetown Corridor, even after expansion, cannot handle the increased services that SmartTrack will also bring. This is a fallacy, as there is a lot of optimizations that have not yet been milked out of it. With $13.5 billion, can buy a huge number of corridor capacity improvements including electricification, faster-accelerating EMUs, USRC, running through trains through Union (connecting Kitchener-Stoufville for efficiency), positive train control, improved dispatching, resignalling of corridors to permit tighter headways, etc). Many countries have milked their corridor capacity far more than Metrolinx has with their tracks. Even the Lakeshore corridor capacity is actually not efficiently used, compared to Japanese and European standards. With a number of modifications to the SmartTrack to make the urban parts of Kitchener-Stoufville corridors compatible with the GO RER initiative and 100% corridor-compatible with all Georgetown corridor plans (e.g. optimizing the services around an express track / allstop track architecture, and slotting fast-accelerating EMU trains between UPX EMU trains, and short headways, as I've explained in previous posts), it is really a very good plan, albiet with some questionable attributes (E.g. the incredibly expensive Eglinton spur, and funding mechanism). It is fairly harebrained if they go with LRT trains fruitlessly attempt to slot frequent-stopping 12-car bilevels between UPX trains. But with the RIGHT kind of train, the many-stop GO RER service branded as "SmartTrack", can be slotted into a 4-track corridor with other services such as UPX. Kitchener express 12-car bilevels (that goes express after Bramalea, or only stops at Weston/Bloor as a limited-stop express), and discontinue 12-car service completely in the 416 stations, to free up corridor room, exclusively servicing the 22 stations (of SmartTrack suggestion) using the GO RER electric train only. Sheer frequency (15min offpeak, possibly ~5min peak) even of a 150-meter single level EMU, will move more people than an hourly 12-car bilevel. And you can use the 12-car bilevels as the limited-stop express. After all, RER = Regional Express Rail. On some commuter-rapid-transit routes (France's RER service is a hybrid subway-commuter train that has subway frequencies during peak period), France operates a bunch of allday limited-stop-expresses interspersed with all-stop trains. During express operation and limited-stop operation, use the 12-car bilevels. During the allstop operations (with infill stations), use the high-performance EMUs that can keep up being between trains despite having to stop more, or kick both UPX and 12-car semiexpresses onto the express track, assuming the performance envelopes can fit the headways safely, especially with enhanced signalling (optimized for reliably tighter headways) and positive train control, to make it easier for the train drivers to safely keep the trains slotted in their schedule without interfering with the train ahead/behind. If the performance envelopes of the 12-car bilevels don't allow them to stop at Weston/Bloor between UPX trains, then just run them fully express to Bramalea.
Assuming infill stations are done from Bramalea to Unionville (i.e. that element of SmartTrack plan is kept), and assuming they plan to keep UPX operating (since it'll be profitable for Metrolinx) then EMUs pretty much becomes essential for allstop service in the Georgetown corridor, or it becomes a hugely expensive waste of corridor capacity (outweighing the cost of EMU trains), unless you want to slow down the UPX trains. Only EMU trains can be reliably slotted at subway-headway densities; no other types of train technology can pull razor-thin headway (when signalling and trackage is optimized as such). Among all train technologies, EMU have a super-huge performance envelope that allows them to either gently or strongly accelerate, all the way to gently or strongly braking, perfect for expert slotting between a diverse range of other train performance envelopes with the tightest possible headways. By eliminating the need to add more trackage, this more than pays for the premium of EMUs.
Possible trains
- Diesel locomotive pulling 12-car bilevels (goes to unelectricified Kitchener)
- Electric locomotives pulling 12-car bilevels (goes to Bramalea, possibly for peak period overflow)
- GO RER EMUs running all-stop service on high density of infill stations (ala SmartTrack)
- UPX EMUs pr DMUs
- Merging SmartTrack and UPX (not financially or politically likely in near future)
Possible service schemes (not all may be done)
- Express to Bramalea (no stops until after Pearson)
- Express to Bloor, Weston, Bramalea (skips infills)
- Stop at Bloor, Weston, Pearson (UPX train)
- All stops at all infills (ala the "SmartTrack" part of GO RER)
Possible corridor-slowdown problems that can happen
- UPX catching up behind a slow 12-car bilevel
- UPX catching up an allstop SmartTrack EMU
- Express 12-car bilevel fully accelerated, but having to slow down because UPX train stopped ahead
- Express 12-car bilevel having to slow down for an allstop GO RER (SmartTrack) train.
- EMU catching up to a 12-car bilevel ahead, because of EMU faster acceleration
- Electric-locomotive driven 12-car bilevel catching up to diesel-locomotive driven 12-car bilevel due to acceleration
- etc, etc, etc.
Various possible solutions:
- The use of common express-allstop track architecture (4 tracks, one express, one allstop, for each direction)
- Share express track between UPX and 12-car express to Bramalea. Dedicate one allstop track to GO RER (SmartTrack)
- Share express track between UPX and 12-car limited stop (Weston, Bloor). Dedicate one allstop track to GO RER (SmartTrack)
- Share express track between UPX and GO RER (SmartTrack). Dedicate one track for 12-car bilevels.
This is very dependant on train performance envelopes:
- Slow accelerating: 12-car with diesel locomotive
- Medium accelerating: 12-car with electric locomotive
- Fast accelerating: DMU (diesel multiple unit, like current UPX train)
- Fastest accelerating: High-performance EMU
The top speed of the UPX and 12-car bilevels are similar, somtop speed is currently a nonissue, but delays caused by stop length (affwcted by stopping distance, dwell, and acceleration performance), which is why EMUs are so criticial for efficient use of corridor capacity if you make stops, otherwise, one needs to avoid doing the stops and just focussing on staying slotted between UPX trains, as part of the word "Express" in "Regional Express Rail", relegating 12 car bilevels to only stations beyond Pearson (aka Kitchener thru Bramalea).
There are a lot of other examples, the above is just a sprinkling of the jigsaw puzzle that Metrolinx needs to fit together, and decide what is possible and what is not.
There is sometimes overlap depending on what is being done, a 3-car diesel locomotive will likely outperform a 12-car electric locomotive. Likewise, an electric locomotive pulling 1 car, may outperform many models of EMU. But for simplicity, the above is usually true.
What they need to do is do schedule modelling of what compatible train performances fit in the service plan. Let's assume the whole Kitchener-USRC-Stoufville corridor has been later upgraded to the latest in state-of-art signalling (e.g. capable of full speed 100kph+ trains chasing each other full speed 100kph+ trains with 3-minute headways, at least at certain moments). Pinch points like USRC, the Bloor station, the crossovers, will have to be modelled for, but if a train can safely crossover between tracks at very high speed while there's a train only a few minutes ahead on both tracks and a train only a few minutes behind on both tracks, that requires a very damn good signalling system like the type of stuff used on some European or Japanese trackage, to make sure it's able to be safely done, and the quality of the control and signalling is so good, that trains behind trains immediately knows to decelerate on time, if there's any problem with trains ahead, during very tight headways. This is frequently done on subways but much harder to do on commuter rail. But with EMUs and complete grade separation, and a very good signalling system, it's certainly altogether possible to do far better than today. Often, a lot of train signalling is extremely granular -- if a train is on a section of track, a whole lot, even a few kilometers, can be off-limits to other trains because of block-based signalling. That can unnecessarily create larger headways than is necessary to be safe. But with modern signalling, positive train control, continuously moving train blocks (or at least extremely fine granularity of blocks), efficient automated dispatch that don't keep trains unnecessarily waiting -- there's such systems in use in some more modern commuter rail systems than Metrolinx's GO system which currently still use older signalling and older operation (no positive train control or automatic train control at all). But let's assume that electrification includes various corridor efficiency upgrades such as these, so with this in mind, let's continue...
EXAMPLE:
(A) -- In schedule modelling they may find the 12-car diesel expresses perform well enough to slot between UPX trains provided they go express to Bramalea. I already know that the 12-car diesels go 140kph; I have used a GPS speedomoeter on the Lakeshore West express and I have seen them reach 140kph whenever they are running late. This is fast enough to keep behind a UPX train. So they can at least start accelerating a 12-car bilevel right AFTER a UPX leaves its station. The UPX accelerates ahead like a jackrabbit, while the diesel slowly accelerates, but eventually the diesel exceeds' UPX /average/ speed, so stays slotted exactly between the UPX trains. They then find out that one 12-car express bilevel then becomes doable with good continuous moving-block signalling (upgraded signalling on entire corridor). Therefore, as a result, they upgrade the signalling to make it possible to slot a 12-car express bilevel between UPX trains. Okay, now you can fit an express-to-Bramalea 12-car GOtrain between UPX trains, so you can run that type of express service to all stops beyond Bramalea, without interfering with UPX. Good.
(B) -- Now, we try to do one better. Now, they try to model if that train has enough time to stop at Bloor and/or Weston (turn the full express into a semiexpress). The problem is that 12-car diesels accelerate much more slowly than either a DMU or EMU, so eventually the next UPX will eventually catch up behind the 12-car. Now, you continue to model to see if there's enough time to do a brief stop and reacceleration. You may find that with upgraded non-granular moving-block signalling that permits a minimum of 3-minute headway moments of full-speed trains, you have a 9-minute sliding window between UPX trains (no closer than 3-minutes behind UPX train ahead, and no further than 3-minutes behind a UPX tran behind). Due to dramatic difference of performance envelope, permit 12-car disels to begin accelerating, say, 1.5 minutes after UPX has left its berth. The 1.5 number varies, but by the time the diesel is entering the USRC and then into the corridor going the same speed as the UPX ahead, the UPX is 3-minute headway ahead because of the UPX's faster acceleration. At this stage, you're now going the same speed of the UPX train 3 minutes ahead. You can slow down the 12-car bilevel GOtrain by up to 9 minutes worth before the subssequent UPX train (15 min frequency) is only 3 minutes behind you (and the 12-car is threatening to block the UPX train's journey). You barely have enough time to stop and then re-accelerate once or twice, managing to squeeze a 12-car semiexpress to stop at both Bloor and Weston (two stops). By the time the 12-car semiexpress is past Weston heading to Bramalea, the subsequent UPX train would be only about a few minutes behind. Hopefully 6-minutes behind, so that it rarely delays a UPX train. Ok, even better, now you can run a limited-stop 12-car GOtrain that stop at the pre-existing GO stations. Perhaps they may find it's only possible with electric-locomotive-driven 12-car bilevel (which then has to short-turn at Bramalea, the end of electrification of this phase of GO RER). Or may be even doable with the 12-car diesels (So it can go all the way to Kitchener). They find out what mathematically works, with sufficient enough safety margin for slower-than-usual trains and reliability problems (and they may find electric locomotives are more reliable).
(C) -- Computer generated modelling of random failures of diesels will calculate where to install crossover tracks so a maximum number of UPX trains can be able to bypass a stalled diesel. They may find it works. But they may find that they can't optimize corridor operations efficiency enough to work around the reliability differences of their various trainsets, and then they may have to avoid using diesel locomotives on the UPX track. But they would have to computer-model and test for this, to find out if it is doable.
(D) -- Instead....alternatively.....They may, also, consequently find that a very good performing EMU (that they were shopping for) actually has enough time for a high-performance decelerate-dwell-accelerate, to be able to service all SmartTrack stations between UPX trains. Let's assume UPX trains are now EMU by then, and the GO RER SmartTrack trains are well-matched EMU. They would then have very similiar acceleration performance. Assuming corridor now has signalling good enough for full-speed 3-minute headways, you have a 9-minute sliding window (excluding 3 mins for UPX ahead/3 mins for UPX behind) to do all the non-Bloor non-Weston SmartTrack stops (the extra stops above-and-beyond the UPX trains). In modelling, they simulate start the GO RER SmartTrack allstop train from Union 3 minutes after the UPX train leaves its berth. If one decelerate-dwell-reaccelerate very quickly (20-to-30-second subway-style dwell at non-major stations), they may find there's enough performance to stop at some or all the "SmartTrack" stations, while still having enough safety margin to not delay a subsequent UPX train. So they find they may actually are able to buy a specific model of EMU that performs well enough to do allstop service between UPX trains. They might find they can do it, but only if they remove one or two of the planned infills, for example (and modify the SmartTrack plan to fit). They will be limited to the UPX frequency, e.g. 1 UPX train and 1 SmartTrack train, interspersed between each other.
(E) -- They may find they prefer to dedicate one track (per direction) completely to the GO RER SmartTrack trains, so that it can eventually increase to subway-style frequencies (20 trains per hour), so that they can run high-level-platform 150-meter trains moving more people than 300-meter 12-car bilevels (that are headway-limited because they aren't as fast-accelerating as EMUs), considering that only seven pre-existing go RER Platforms need to be modified to go high-level, in order to make it possible for Metrolinx to purchase a specific EMU that they might be looking to buy, in order to make it possible to squeeze a specific service plan, as an example (...see, that's why I think Kitchener GO RER route is a de-facto EMU, if they want extra infill stations, and if they don't want to interfere with UPX....)
Obviously, they have to simulate and jiggle things around, to see what works, what fits in the corridor, but if commited to keep the services they plan, they will definitely come up with a service plan that fits all the planned services. There is already four tracks on the Georgetown corridor (and extra tracks can redirect Milton/Barrie service, keeping four tracks for UPX/SmartTrack/Kitchener trains). Yes, the difficult Bloor area can actually be rejigged to fit six tracks (which will help frequent Barrie/Milton trains a lot). My prediction is the four-track express-allstop architecture, with express track assigned to UPX/expresses/HSR and the allstop track dedicated to allstop GO RER with infills (ala SmartTrack).
Please bear with me, sometimes my train terminology is incorrect; the ones that railroad engineers use is sometimes different than what I am trying to describe, but the Europeans and Japanese have some amazing train-service-modelling computer programs, and Metrolinx will need to push the corridors to highly efficient signalling that permits tight full-speed-train headways, for maximum flexibility in designing service plans (like above examples).
The people who say Metrolinx will not be forced to choose EMU, do not realize the challenge they are going to hit hard, if they want to keep the UPX train AND also add lots GO RER infill stations (Even if not as many as SmartTrack suggests).
The people who say Metrolinx can't squeeze all the services into the corridor, do not realize what is safely truly possible after a lot of efficiency improvements on a fully-grade-separated, extremely-well-signalled, extremely-well-operated electrified corridor. The georgetown corridor has great potential to reach this impressive European/Japanese status after a few more billion, and manage to successfully simultaneously squeeze GO RER (equals SmartTrack), express Kitchener gotrains (which may eventually be high speed Kitchener trains in the future), and UPX trains, onto just four tracks (two per direction), if tweaked accordingly.
There are going to be some challenges for sure, but nothing that several billion dollars can't eventually solve.
Things become a lot easier if you cancel UPX and/or SmartTrack-like infill stations, but, assuming, of course, they keep all these elements, they are going to have to run the corridor to highly modern commuter train standards closer to many well-operated European countries (e.g. France). It does not even have to be legendary Japanese train-slotting super high precision, but that, too, can further help if the corridor eventually runs high speed trains in conjunction with all the other services.
