TheKingEast
some walls are better than others, I don't think it is intentional.
Even the precast window sills are crooked.
Why can't they go with a rough brick instead and lay it properly?
Exactly. Everything looks sloppy and crooked.
Queen Richmond Centre West by Marcanadian, on Flickr
Queen Richmond Centre West by Marcanadian, on FlickrIt is 100% intentional. Look at the material used itself and you will see that it is not possible to lay it evenly because each piece of the high end "brick" (stone) being used is unique. You are just not used to seeing real material with its inherent character preserved being used. this is what happens when you get comfortable in the pre-cast red brick world of Toronto. I am glad to see someone trying to class this place up. i would live here if I could afford to. One of the best buildings int he city without question.
Go Have a look at the brick itself and yes it is intentional. 1000%Not talking about the stone work above, I was talking about the brick work on the previous page and no, it's not intentional...
Good mood + good lighting + good weather = me like
What would Frank Gehry say?
=Today, 12:09Designerguy
^^^ I totally agree too. The stone looks good, but the brick is just very sloppy.
I have seen rough brick laid elsewhere and any qualified bricklayer should be able to lay each row in a straight line as it should be.
Not only the bricks are not level vertically, but they are also laid slightly askew creating a buckled and uneven appearance of the surface. It's not the brick that is doing this as it appears to be pretty flat.
It looks particularly bad in sunlight where the shadowing emphasizes the uneven and irregular surface.
If this was supposed to be intentional than why are parts of the wall is more wavy and uneven than others?
Luckily there is not much brick used here and not on a prominent part of the building.
