Koops65
The sign only says 228 metres... did they forget the mechanical?
They don't count mechanical on those signs. Always heave to read the fine print for the real heightThe sign only says 228 metres... did they forget the mechanical?
As a mid-rise building, 145 Wellington suited the development climate when it was completed only 33 years ago, but the conditions are so different now that it's practically obsolete. The embodied energy that the existing building represents is substantial, so yes, every way of reducing the carbon footprint of the new building should be employed in the redevelopment. When this hits the DRP, no doubt the sustainability expert on the panel will look to encourage more attention in that regard, they'll likely push for adherence to the incoming Toronto Green Standard Tier 3 or 4.I live in the area and just got the community consultation notice. It's going to be Jan 23 @ City Hall Rm 4 from 6:30-8:30. I had no idea the site was rezoned. Kind of crazy a ~30 year old building is already being torn down. It did seem like the offices had been emptying out for the last few months. I'm kind of sad to see it go.
Can they add a green roof or solar panels? The RBC Centre across from it was certified LEED Gold, I feel like they owe more to the environment for demolishing a perfectly usable structure. I still sometimes grab lunch from the mom & pop sub shop (Lite Bite) but now it probably get replaced by a Tim Hortons instead.![]()
Not sure I agree.The Globe & Mail put out a story with the same sentiment I have about teardowns
By wrecking tall buildings, are we contributing to the climate crisis?
There’s a growing movement to view existing buildings as resources of ‘embodied energy’ that need to be preservedwww.theglobeandmail.com
I think the Globe‘s point was that the only reason we’re tearing down 10-storey buildings is because our restrictive land-use policies are pushing developers towards tearing down mid rises and buildings energy-intensive concrete tall ones when we could be tearing down hundreds of km2 of one and two-storey houses and building four-storey wood-frame apartment blocks for a fraction of the economic and environmental cost. They further point out that if we could rebuild swathes of suburban detached housing, property prices would drop significantly, solving (at least in part) the housing affordability crisis.Not sure I agree.
First, you aren't simply replacing a like-sized building with another like-sized building for aesthetic purposes only. You are increasing density in an area that can support it. At the very least, the argument for intensification likely counters the argument for not moving forward with projects like this. Your sentiment also assumes that if this building isn't torn down, you now save the planet from the carbon that would otherwise have been generated constructing the new build - but that is flawed. You still need the new build, it will just go elsewhere now, but the carbon expended in constructing it remains the same. You just have a less dense area in the part of the city that is best suited for it.
That said, I do agree with you in a scenario where intensification isn't taking place. But this is not that scenario.
Cheers.
I caught the tail end of the meeting but it seemed like a handful of area residents showed up. Some takeaways:
- The development calls for reducing one lane of vehicle traffic on the southeast corner of Wellington & Simcoe as this would accomodate increased sidewalk space for the high ratio of pedestrians to cars
- A resident requested the city planner if cycling direction on Simcoe could be changed to one way. I would agree as one way traffic is safer for pedestrains.
- H&R built the existing 145 Wellington in 1987 and they plan to keep ownership but that could change
- H&R is planning to keep all residential units in this building as rentals but that could change
- H&R is only aiming for the Tier 1 Green Standard unless the city pushes back for higher
- I suggested removing the balconies, The Ritz nor 33 University have balconies, besides providing more living space & making it easier to control the buildings climate, it would give a cleaner look & the property manager won't need to deal with falling glass or things being thrown off it
- I gave positive feedback on the website put together by Bousfields, I wish more development projects did transparent community engagement this way
