^More roof area may matter in bad weather. If everyone huddles under the wee bits of shelter, when a trainset arrives, there will be crowding at a few doors and no one boarding at others, The result will be longer dwell time.
The roof should be long enough that people aren’t bunched on the platform.
I'm not sure we should want Montreal metro-like speeds for opening the doors, but at the same time, I cannot disagree with you. What is interesting though is that the TRs used to be a lot worse. I'm not sure why bombardier's door times seem to be slightly longer than other city's (with the exception of New York, where the guard has to close the doors in parts on most lines).Honestly the largest contributor to dwell times I have seen on the new streetcars is by far how ungodly slow the doors are to open and close. Its unreal. What an engineering fail.
This seems to be a systemwide issue. The subway doors take forever to open/close on the new TR rockets, the new fare gates take forever to open and close. Something about modern systems/actuators that are making doors a nightmare in modern systems.
This is the one thing I miss about the H series cars. The H2 and the H4 cars would leave a bruise if not break a rib should you be caught in the closing doors. They were a virtual guillotine.
Those doors were deadly and I doubt the TTC wants that to happen again.
I'm curious as to the actual time between opening doors and closing them, and wonder how it's affecting service. Theoretically, it isn't as bad as it was because lines 1 & 4 are all TRs while Line 2 is all T1s, so it's likely that the difference in dwell times aren't affecting services on the subway, but I can guarantee it's a bigger issue for the streetcars (especially since they take even longer to open and close).
I'm not entirely sure what's causing it, but my best assumption would be differences in the train's software, and the increased level of safety implemented. If it really is a huge issue and it is software related, I'm sure the engineers at bombardier can fix the issue if enough people complain.
Well you see, door holders should be fatally injured if they dare get caught by the doors when they’re closing.I dunno, the door rushers that delay the line by forcing the doors open might reconsider next time
Blame the TTC, that's how they sped'c the doors to open/close. If you think the Flexitys are bad, just look and how long it takes the TTCs NovaBus fleet to open and close rear doors. Half the doors on the fleet are becoming flimsy partly based on the amount of force people use to open a door they think isn't opening for them due to the time delay on the doors.Honestly the largest contributor to dwell times I have seen on the new streetcars is by far how ungodly slow the doors are to open and close. Its unreal. What an engineering fail.
Should operate the same as the flexity outlooksBlame the TTC, that's how they sped'c the doors to open/close. If you think the Flexitys are bad, just look and how long it takes the TTCs NovaBus fleet to open and close rear doors. Half the doors on the fleet are becoming flimsy partly based on the amount of force people use to open a door they think isn't opening for them due to the time delay on the doors.
As for the Crosstown fleet, the door specs would be up to Metrolinx (the TTC has no say) which may, or may not be a good think depending on how fast/slow the doors will close.
