salsa
If I kick the base of the CN tower does the top sway?
If you wait for a good gust of wind to strike the tower, and time your kick perfectly to that wind... you might be able to trick some people
Yes it should take longer but ML has delayed the project significantly to reduce cash flow at the orders of Queen's Park. Basically 2015-2018 is wasted as mass excavation should have began in 2016 not 2019. It takes an average of 5-7 years to complete a subway regardless of length as long as there is enough workers.1. Eglinton is in no way going to be overbuilt. Have you seen the station renderings?
2. It's a subway that's 4* as long as Ottawa's, of course it's going to take 2-3* as long.
The Crosstown platform length are the same size as the Ottawa Confederation line platforms. Those 2 car trains would fit the station perfectly. I'm sure people would be saying Ottawa is underbuilt but they are only running at 40% capacity. If they operated at 20-25 trains per hour instead of 14, there wouldn't be much crowding on the platforms and on trains. Of course they went cheap...Other jurisdictions (Vancouver, Montreal, K-W, Ottawa) seem to build these things within 5 years. We take 15 years on average and when we are complete the public realizes just how massively overbuilt the projects are. Lol indeed... lol of tears and regret!
The typical station box accommodates a 90 metres platform with a 40 metres service area at one end and a 20 metre service area at the opposite end resulting in a total station box length of 150 metres. Initially the LRT operation will consist of a 2-car trainset requiring a 60 metres platform. To protect for the ultimate 3-car train set the 90 metres platform would be constructed, but then temporary walls would be installed to create the initial 60 metres long platform. A 2.5 metres wide corridor would bisect the remaining 30 metres reserved portion of the platform leading to an additional secondary entrance.
Yes from a kick. A few assumptions.Not from a kick. The antennae sways about 1m from center during high winds (100kph), and the skypod (being lower) about 0.5m from center. We get 100km/h gusts every few months.
Next time it's windy, buy a ticket to the skypod and take a pendulum.
It's 90m at street level.I thought they were actually shorter 90m vs 120m. Surface in Ottawa is 90m, but the tunnel has longer to allow 5 module LRVs in the future without an expensive underground rebuild. The crosstown on the otherhand has 90m underground stations to allow 3 Flexities to be connected. I'm not sure if they are the full 90m at street level though.
I wonder how hard it would be to turn the service areas into a platform if they decide they want to go to 4 or 5 cars per train (120-150m).
That's the point of building them like that. All of those services and utilities can be moved if absolutely necessary and relocated elsewhere.
It won't be cheap, but it will be cheaper than trying to extend the station box to lengthen the platforms.
