Hopkins123
Doug's position in 2014 was to grade-separate the entire section from Laird to Kennedy.
That was the right decision then. Unfortunately, saner minds did not prevail.Doug's position in 2014 was to grade-separate the entire section from Laird to Kennedy.
Speaking of which, it may not be possible for DoFo to cancel the whole project, but can he just cancel the above ground portion, since it fits "the damned streetcars" definition?
At this stage, I don't think he could cancel it.
If I were him, after the election, I might announce that I will explore means of grade-separating it. This delay of a month or two would not be excessive, and when the costs come in, he can say its excessive.
Ideally for him, it will show that the cost would have been negligible if done correctly from the start, but at this time there is no turning back. That would just provide more proof on how much this line was messed up when Council and the Liberals went against Rob.
I don't know exactly what the state of construction is, but I guess that the Scenic Portal (east of Brentcliffe) and the Don Mills-Eglinton Station are already set.Wonder how 'late' it is for rethinking Crosstown between Laird and Kennedy. If it means that we keep Line 3, and subsequently interline this with Eglinton to SC, I think right and left would be on board. Even if it delayed Laird-Kennedy section by 5-10yrs.
We'd obviously drop SSE which many seem to want, and we'd offer a subway to SC (that actually has inline stations!). We're already rethinking Crosstown between Black Ck and Pearson by adding grade-separations, so it's not unprecedented to reconsider what kind of transit Line 5 is supposed to be. Net and political benefit could be somewhat positive. Also boosts business case for expanding RLS scope to Eglinton as a Phase 1 imo.
The onus would be on PCs to embrace affordable grade-separation (open air, cut/cover, elevated). Something I'm dubious about.
Delay 5-10 years?! Then it will end up another studway that is never connected to other lines.
No, just a higher order transit10 km through a central section isn't stubway status.
I know this isn't the best thing to compare the Crosstown to, but the Viva Rapidway construction is/was much better than the Crosstown's surface construction in terms of organization, clarity, and ininconvenience.
As I said, it’s not a fair comparison as tha scales are different in terms of size and area to work with. The most comparable (so far) would probably be around Don Mills Road.And how much of the Rapidway is underground in a narrow roadway?
Pretty interesting video showing how the tunnels will look
