^ English has a superb preposition for just these occasions, and it has two letters, and is is phonetically pronounced as per spelling: "At". And if you wish to shorten it even more in writing, there's "@".
When using the crossroads to denote the station's name, it would be Bloor @ OSSINGTON or the like. The intersection is capitalized, the common name of the route or line is in lower case. I need a coffee for that...
Locale can still be added as per above: Bloor @ BAY for YORKVILLE. Where a location isn't easily defined by street intersection, Line 2 @ OLD MILL for Humber River
Just about perfect. The dominant labeling as Bay makes clear where the station is while the sub-heading name refers to a locale.
It's too bad that Metrolinx's consultants couldnt figure that one out. What even more embarassing is that they had to pay consultants to come up with station names, and the only thing those consultants did was use the exact same naming coventions Metrolinx currently uses to name stations.
This has been done before. Bay Station was and is labeled BAY - Yorkville as seen in the attached image from Wikipedia. Bay is the cross-street while Yorkville was the neighbourhood. I believe this was done in response to the interlining experiment wherein they wanted to replicate the naming system along university .View attachment 165957
They should do this on the Crosstown, but Metrolinx has there own naming rules...
It’s a little soon to be stressing about LRV delivery. This and similar issues are the bigger concern. There are some pretty huge holes out there along the line - need to start a station by station watchlist of progress.
Councillor Josh Matlow: “The overwhelming response is of tremendous concern, principally because of the incursion of traffic that will result from this.” So he's concerned about traffic but wants to delay the opening of the system that reduces it. Right.
So the advantage of deep bore TBM construction is less surface disruption than cut-and-cover.?
It is becoming apparent that TBM construction has many negatives that don't get mentioned during EA, while the advantages of cut-and-cover are ignored.
It's one of those archetypal Toronto things. Any mention of cut and cover gets instantly shouted down by people with photos of Yonge street in 1951. But no one remembers the last project we tunneled.
While I don't agree with Matlow, I also sense that he represents some of the hardest to deal with homeowners within the 416.
"Lt's make traffic much worse to them nake it better." For a politicain who always worries about getting reelected, that would not make sense.
When the Bloor Danforth and Sheppard extensions are built, it should be cut and cover to eliminate delays.
