 7.8K     0
 38K     0
 4K     0
On a side note, I've noticed that lrvs are running again. Have the track adjustments been completed?
Prior to the website going down, they had put out construction notices for some quick-and-limited construction work to be done at many of the at-grade intersections. Those dates have come-and-gone, although I neither saw the work occur nor do there appear to be overt signs of the construction having happened (say, fresh concrete, new asphalt, etc.) - but at the same time, the work required may not have needed that kind of intervention, either.
At least at Leslie, as of Friday there was no indication that an LRV had passed through there in quite some time. The rust on the running surface of the rails is quite heavy, and the grass is long enough that it will likely require a grounds crew to mow it in the near future. At least the sprinkler system seems to be working reliably.
I did see an LRT testing at night by Warden and Eglinton. The Grey absolutely makes it feel/look like a subway car.
We may not have trams running yet, but the first time that a Toronto transit line reaches the point where the grass between the rails is too long - is a historic moment in its own right. UT'er should celebrate.
If the Euros can run all bushy I don't see why we need to go Brazilian.
some construction pics of Laird station
Laird station 1km caved out storage area for third track
