Although this may not be a good idea, I wonder if the design will have the possiblity to have buses drive on the elevated structure to get to the Transitway?
So they did this just to make the automobile gods happy I see?
ensuring traffic flow for both the LRT and your family’s Ford Nation bumper-stickered SUV.
No extra signal phase on the eastbound off ramp, but instead an extra phase on the westbound off ramp, which doesn’t have an extra straight route.^ In looking at the comparison images I provided above, I don't see that much of a positive difference for car drivers. Happy to hear a counter argument.
Fixed it
From Robert Speck to Square One Drive, it's about 175m. If you move to the West side of Hurontario South of Speck, you could elevate in this distance.Based on view of the current plans for moving the LRT from the center of the road to the west side of Hurontario, this is about the location where it will take place south of Sq One Dr. Can't see it being elevated since there isn't enough room to raise it starting at Robert Speck to keep it under 5% grade. This mean the line will be at grade crossing 2 major roads.
I suspect this gate arrangement would be for Robert Speck (if the LRT moves to the West side a bit earlier).Crossing Sq One Dr will be as close as it can be to the existing sidewalk at grade and will require traffic to stop further to the west to not block the tracks. Going to need crossing gates at this location if tracks are at grade.
I suspect that, if needed, the SB to WB on-ramp could be altered a bit to become more of a 90 degree turn than the long, smooth ramp that it is now.The line is to swing from the west side of the new 403 LRT bridge between the 403 and the 403 on ramp. One hope its elevated and has to be to get over the eastbound 403 off ramp. Enough room to get down to grade before Kingsbridge at 3% grade.
None of the existing ramps are to be touch from what I have heard.From Robert Speck to Square One Drive, it's about 175m. If you move to the West side of Hurontario South of Speck, you could elevate in this distance.
The extra ~250m of elevated track would add maybe $25M.
There is not even 100m from Square One Drive to Rathburn - so at first glance it appears hard to elevate here - but Rathburn is a lower elevation so it can likely be done.
