Allandale25
Latest Metrolinx blog post.
![blog.metrolinx.com](https://assets.metrolinx.com/image/upload/v1662629754/Images/Metrolinx/iStock_000004833268Medium.jpg)
City council chose Queen because it was the preferred by planning. They wanted to connect it to city hall and claimed it would serve underprivileged communities better. The King alignment projected a higher ridership.King was too narrow for the station boxes, that is why they choose Queen. And as to why no above ground portion along the railway ROW? They asked the community and it was a firm no, even when offered a station at Queen.
Ridership was only marginally higher. Queen is superior because King is too close to the GO corridor anyways. The walk between the two streets is insignificant anyways.City council chose Queen because it was the preferred by planning. They wanted to connect it to city hall and claimed it would serve underprivileged communities better. The King alignment projected a higher ridership.
Did you know that 40% of the New York City Subway system is ABOVE GROUND!
From link.
Map of line elevation in relation to the ground; underground segments are in orange, and above-ground segments are in blue, whether they are elevated, embanked, graded or open cut
Cool. Now when do we get to see some actual designs? All this is just vaporware until they can prove that the scheme would actually work.Latest Metrolinx blog post.
Note that all Manhattan lines, Queen's Boulevard, Fulton, and Concourse are in super dense areas, all run underground, and carry the most people for a reason. Of the aboveground lines, the elevated ones are the next busiest and run in areas that are not densely populated (white Plains, 7th Avenue, Astoria, Canarsie, BMT Broadway, Dyre, and Flushing). Comparing the NYC system to the Toronto system really reinforces the notion that the EWLRT should be elevated like the White Plains Road line, while the Relief Line should be built underground, at least, south of Danforth.Did you know that 40% of the New York City Subway system is ABOVE GROUND!
From link.
This is the case with a LOT of large subway systems.
Queen's catchment area is probably larger and more diverse. A walk from Dundas to Queen is 500m, and another 500m to King.Ridership was only marginally higher. Queen is superior because King is too close to the GO corridor anyways. The walk between the two streets is insignificant anyways.
Dues the mural under the covered bridge count?Omg I'm so excited for unique architecture and beautiful, neighbourhood defining transit stations.
Yep. In fact, more than half of the London Underground is above ground.
