"Becuase there still isn't agreement on what the meaning of "white" is."
Yes, but that's no different than saying there isn't agreement on what the meaning of "visible minority" is -- in this context it is precisely Statscan's decision of what the meaning of "white" is (www12.statcan.ca/english/...p127.htm).
It is funny how the professionals working for the City of Toronto cannot draw maps correctly. The % VM population of census tract is what should be represent as a shade of red, not total VM population.
doady:
Please read the fine print of the subtitle: Persons AND percentage
The colours are representative of the former. There are circumstances where it is more useful to have number of visible minorities in the tract than percentage, such as the level of ethnospecific service needs.
I know the colours represent the number of persons. I'm just saying that it is incorrect to use colours to show totals on a map. Colours should only be used to show rates. The map is wrong, it is simple as that.
Not necessarily true. A darker/lighter shade can represent density or concentration as well as absolute number. There are many types of demographics where rates may not necessary make sense, or where absolute numbers are needed, as Alvin pointed out.
I have a Masters in the field, BTW.
^ If for no other reason, the map makes sense as is because the five digit total VM figures - which need to be included for the rates to be properly compared, for servicing as Alvin says, etc - simply won't fit into all the borders of tiny little census tracts, while the shorter rate figures do. It may look "wrong" but smashing numbers together would look worse.
I'm am not saying that using totals is wrong, I'm saying that they used incorrect method for showing totals. Shading is not the correct method, they should be using dots (as in the second map) or graduated symbols instead. Like different-sized circles for example.
The reason for this is because a map must be intuitive and easy for people understand. If you want to show totals, it makes sense to show this using size or numbers of dots in some way because these are totals as well, or can be measured as total numbers.
Shading is makes sense for rate, because that what a shade is: a relative intensity or density of one colour, perhaps compared to another (in this case, red with yellow). A colour or a shade cannot be represented or measured as a total number so it in turn should not represent total numbers. I know I am probably not explaining this properly, but I hope you guys understand what I am saying.
When the average person looks that map, they think the east-side of downtown hardly has any visible minorities at all because it is shaded yellow, even though more than half the population belongs to a visible minority. It is shaded yellow simply because the neighbourhood is small and so the total population was low to begin with, and so the VM population is low too.
On the other end of the spectrum, the neighbourhood west of downview airport is shaded completely red because its boundaries are huge, even though it actually has lower % of VM than east downtown.
The map is very misleading, and people will get the wrong idea from it. If they wanted to show total and % VM population at the same time, they should have used graduated symbols for the total VM population and shading for % VM population.
^ We're talking visible minorities. If you're born in Toronto to Chinese parents, you're still a visible minority.
That's nice, you could be four generations in Toronto, and you're still labelled as not quite being one of us. I'd say Toronto does not have a visible majority any longer, so the term visible should just be dropped. A black person from Ghana has as much or little in common as an Irishman or a Chinese man, so there's little point in throwing the Ghana and Chinese people together unto one label.
^Just imagine what happens when visible minorities become the majority?
I'd say that if you added up all the visible minority folks in Toronto and the GTA, they'd be the majority. Nothing wrong with that.
So no majorities, all minorities.
I see nothing wrong with that, either.
