What's so awful about Option 1? Being consistent is a big plus. Besides, the general layout of T1 is still relatively modern I'd say. I don't think anything big has changed that would require a redesign
Issue with Option 1 is that it's not extensive enough. Sure, giving us G is good, but we need H on top of it as well (which was originally proposed as a 2-pier section).
Remember, YYZ is still low on gate space, even without a full return of traffic, and with the population boom, it's only a matter of time before G/H fill up themselves. We're still using the IFT after all.
It was explained to me by someone that the 'piers' model is being moved away from globally, as the traffic implications of planes getting going in and out of 'dead ends' is not preferred from an aircraft movements and ground logistics perspective...meaning bridged islands that offer full circulation of aircraft are preferred. The current layout is also not as conducive to snow clearing activities compared to islands.
Indeed, the "toast rack" design -- with linear concourses linked underground or by overhead bridges -- seems to be the industry standard now. Pretty boring to look at from a satellite photo, but the benefits for aircraft movement are obvious.
But unless you have the underlying passenger infrastructure to transport passengers between those concourse, it becomes a huge pain in the a** to get between one concourse and another. Heck even if you do, it can still be a cumbersome mess.
Just look at Hartsfield in Atlanta, good luck trying to make a connecting flight if you've got 1-2 hours in between them. They can accommodate a lot of aircraft there for sure, but moving between or inside the concourses can be a nightmare with how busy that airport is.
It would mean YYZ going full circle. The initial "aeroquay" plan is literally the OG island terminals plan. Then we got T3 and new T1 that were piers models. Now we are going back to islands...
If anyone remembers old Terminal 1, they'll remember that the terminal was incredibly compact. Not much distance to walk, but then again, that was before all the security requirements, so a small building like that probably wouldn't have enough space for today's needs.
Offhand, I can't think of any modern airport that has security in an island. The island at Terminal 3 has no security.
True - if they move to islands, then there would be a main terminal for check-in and security then a shuttle train to the island terminal.
I was thinking of the original Terminal 1, which was standalone.
I finally got a good chance to take a leisurely walk around T3 (before security) today since they finished their renovations. (I've certainly flown out of it a few times since Covid, but all I want to do then is get through security.
I hadn't realized they were ripping ALL the shopping out of the terminal! It's really quite pathetic now - and the food choices are very meagre, with virtually no seating.
Perhaps the best food surprise though, is that there's a Smokes Poutinerie truck on the very east end of the lower (arrivals) level. How they got it in there I don't know.
I also noticed that near to Smokes just to the north, is a pair of escalators leading down to the basement(?), and a passageway that would head back under T3 heading south. There was zero signage, but also no restrictions. I should have gone down for a look - as it doesn't appear on the detailed airport maps. Does anyone know what it is?
Hmm. It's certainly shown on the GTAA's terminal map but the escalators seem to go nowhere. As there's no matching escalators on the other levels of the terminal. That it leads to a hallway under the terminal makes me think that it's for access to the post security area.
screen cap of the escalator:
