I am in shock at how small these look along that stretch with all of the other proposals in this image.
Interesting that the below grade levels have just changed from 4 to 5 in this submission considering the pit was bottomed out a long time ago.
it would have already been built.
It is a bit odd - but you don't need a zoning or OPA change to build more parking, generally speaking. Just file your permit and amend your SPA application.
How do they expect to increase the below grade levels from 4 to 5? They have finished the excavation and are probably at garage Levels 2 and 3 already.
As I said, it was likely already built as such but not picked up by UT as you don't need to amend your zoning to do so.
It seems it was always 5 parking levels - P1, P1 Mezz to P4
Slightly different information on details. I guess they just tweaked the depth a little and kept the same design.
2020
2024
2020
2024
My mistake, you are correct; it was previously 5 u/g levels and remains 5 levels in the current submission
How worried should we realistically be, given this is HPA?
Depends on whether Pinnacle decides to use at least some semi-decent looking materials here.
We've seen time and time again where an architect's design is hamstrung by a cheap developer (ie: there's an ongoing project in Liberty Village where HPA's design is being wasted by BGO's cheapness).
The fact the developer if Pinnacle One is of any indication of...doesn't have to use cheap materials. At all.
