Just found two very similar renderings for the retail area... the first one is from BDP Quadrangle's website.
Does anyone know which one is currently getting built?
Those appear to be identical but likely just done on a later round of renders after changes were made elsewhere. Just looks like the angle and the quality of light was changed.
Are we playing "Spot the difference?"
One uses different hues, lighting, brick and render people arrangement from the other...
...and if one of these is in fact a later version, consider it a sidegrade as opposed to an upgrade. As either will work once and if built to that respective spec, IMO.
Biggest change I see is the cladding colour of the underside/railings of the third storey mezzanine; it's gone from a bronze-y colour to dark grey with red. They've added some lighting to the railing and bridge underside as well.
How did I do? lol
Nope, here's the dream situation, where the artisanal potions vendor has a three-level luxury display :
ric1055_wellretail_s050_int_underpass_final5000-jpeg.377358
And here it is after The Cheapening™ where the snake-oil peddler has gone down to a simple four-leg table:
the-well-4-jpeg.377357
Been a while @Red October. Cheers!
42
Missing potlights under the L3 balustrades, and illumination under the skybridges; and one of the skybridges between the two podiums on the left went from an open truss to covered up. Minor changes, but it's there.
EDIT: oh and the flooring for the retail went from narrow to wide tiles on both sides. The truss pattern of the bottom of the skybridges have also changed.
