That's the design speed of the vehicle using that motor and transmission. Using the more common Voith T312RE transmission would have resulted in a top speed of 125mph.
The speeds that you are quoting are the maximum speeds that were projected to be attained by the two starting services - SMART in California and UPX here, respectively. Of course, as we now know, the top speed that the vehicles attain in service here in Toronto is 80mph.
Fascinating. And since it's 'already posted in this thread'...could I impose upon you to reference or link that? If true, it seems VIA have their HFR train of the future.
Meantime, re Reaper's concurrence on "rough ride"...
10.22 Cardan Shafts
The cardan (drive) shafts shall have a double universal joint, splined
arrangement, and shall be torsionally resilient to cushion torsional shocks
between the truck and the transmission. The damping characteristics and power
rating selected shall meet the transmission manufacturer's recommendations.
The cardan shaft shall be designed for the worst-case track curvature and route-
specific speed/curvature profile.
Cardan shaft safety hangers shall be provided and shall meet the requirements
of 49 CFR 229.99.][...]
http://www2.sonomamarintrain.org/userfiles/file/Vehicles -Draft DMU Technical Specification 1-20-10.pdf
Oh boy, that probably explains the bogies 'feeling light'. They are! If the drive motors are body mounted, this *further* renders electrification as bizarrely complex.
I can't locate it now, but Metrolinx used to publish a web-page on how simple it will be to "just sub in electrical changes" and voila! EMU in a jiffy!
I suspect they took the page down. Too many people refusing to drink the Kool-Aid.
Bombardier had actually proposed a loco over a decade back for HSR (one presumes) with a prime mover in body, and a Cardan shaft to the bogies. I wonder if that's still on Bombardier's roster? Ostensibly less track wear, but trying to get that bogie to tract might be a real problem, unless the loco's traction transformer is like carrying a ton load in the back of a pick-up truck
Edit to Add: Indeed, it is Bombardier's TRAXX series, the forerunner described here:
https://en.wikipedia.org/wiki/DB_Class_101
In the event, these locos are quite heavy, even with every effort to lighten them, and in the 101's case, the xfrmr is slung under the chassis, effectively adding to the tractive factor.
Perhaps Dan will link a source that explains how Sharyo do this with the UPX DMUs? And further to that, the complications of doing this in lieu of hydraulic drive motors mounted directly on the bogies? I suspect the complexities of doing a 'direct mechanical drive' from the mechanical ZF gearbox compounds in complexity from normal practice with an all-fluid drive system, where only hydraulics are connected to the bogies, brakes and thrust.
Curious....still digging.
Late edit: From Cummins PR page on the Sharyo DMU, albeit all references appear to apply to the SMART specs:
Compact Underfloor Power
The horizontal envelope of the QSK19-R allows for a highly compact installation within a self-contained power module positioned underneath the railcar body. This space-efficient installation enables a flexible seated capacity of 180 to 237 passengers for the three-car DMU train set, together with additional space for standing passengers during busy periods. Passenger convenience is further enhanced with step-in level boarding from the platform and allocated space in each railcar for up to 12 bicycles, wheelchairs or strollers.
On-board power such as air-conditioning is generated from the QSK19-R by means of a high-efficiency drive shaft, eliminating the need for an additional engine for hotel power.][...]
https://cumminsengines.com/cummins-qsk19r-to-power-nippon-sharyo-dmu
Note the lack of reference to bogie drive! Curiouser and curiouser. I'm just dying to see these spec sheets that are reputed to exist in this forum...
From the Nippon-Sharyo website:
Delivery years Car type Photo Customer Maximum Speed Qty
2015 PC
METROLINX (144 km/h) 16
144km/h = 89.4775 mph (let's just call it 90 mph)
http://www.nipponsharyousa.com/products.htm
