tsm1072
Active Member
I had a look at the Richmond Hill Centre Secondary Plan (Here) to see how the new proposed stations may integrate into the eventual development sites over the next 30 years. Here is a slide with an overview of what they would like to do:
The new High Tech station ends up being fairly centrally located in the development area. If they go with the proposed plans, you will hopefully have a station with storefronts, offices, and residential packed tightly up against the ROW, hopefully with a few extra pedestrian crossings north and south of Hight Tech Road. This will primarily be a walk-up station, so limited parking for the shopping areas should be all that is required.
Bridge station is mainly a transfer station and the walk-up station for Langstaff. Ideally, they remove the parking from the hydro corridor, and it acts as a nice large park. Using the hydro corridor and stormwater pond should provide more than enough green space for the area and provide and somewhat pleasant walk-up to the north entrance of Bridge station. Commuter parking will be important to integrate, and I think the perfect use for the deadspace between Hwy 7 and the 407. They can have parking space the whole distance from the 407 off-ramp in the west, to the Cedar road extension in the East. You can make it a multi-level lot near the station, and probably fit some parking under the bus terminal.
The re-alignment of stations to use the rail ROW definitely opens up additional development space, and hopefully will force better pedestrian access across the ROW so the whole area doesn't end up feeling divided down the middle by the tracks.
It's not mentioned in the IBC how far north of high tech the new yard will be, but I hope they allow space for a grade-separated MUP from 16th Ave all the way to Bridge, similar to the West Toronto Rail Path. This is an opportunity to provide some high-quality pedestrian and bike access to stations that aren't just painted lines on a road.
