Contra
Any reason they haven't switched over to pantographs yet? Most of the lines have had their cabling redone so surely they should now be capable of supporting such a system...
Because 'most' is not 'all' and until all of a line (and its detours) have converted you must use poles (or have operators constantly switching and if they forget ....)Any reason they haven't switched over to pantographs yet? Most of the lines have had their cabling redone so surely they should now be capable of supporting such a system...
What happens if they use both the Pantos and pole at the same time by accident? 88mph and then its 2015 and we have flying hoverboards?
That's not likely to happen, we have a strict procedure we must follow when changing from pole to Panto and vise versa. There is a switch in the streetcar that only allows one method of current collection to be active at a time.What happens if they use both the Pantos and pole at the same time by accident? 88mph and then its 2015 and we have flying hoverboards?
A number of cars had issues getting the pans up with the supervisor showing the drivers how to lower the pole and put it backup as well dealing with a pan that refused to raise. Watch 2 cars spend close to 5 minutes trying to get the pan up with the supervisor opening the compartment under the pan and doing something there as well in the cab. Came out of the car a few time to see if the pan was up and did some more checking in the cab. Should only take 10 seconds for the pan to raise.
While there is a cutover switch for current collection in the cab, there is a master switch and controller in module C under the pantograph. If the switches aren't set correctly the cab control won't do anything.
The earliest you need cars for Portland is 2030 as the land will not be ready until after 2025. The new Cherry St bridge can't be built until 2021/22 and only then if there is money for it since there is no land yet to build the south pier support for it.
TTC should had done 1:1 from day one and that 252 alone and you would need more just to deal with pend up demand then, let alone today.
Sure hope TTC looking for another yard for these cars.
Other comments will come after Sept 18 when I can talk about it then.
This RFI is a year or 2 late, but nice to see it.
