Towered
We need to consider a wider network. Old Toronto's west end lacks a north-south mass transit line. Jane would be ideal for one. There should also be another one in Etobicoke.
I agree with all of you they need to do Jane in phases.
Ph # 1 ECLRT - North up Black Creek dr from Mt Dennis to a the 1st stn @ Lawrence. NWCorner then over base of the 400 & land on Jane in the center to Falstaff then Wilson all the way on top to Steeles or 407 preferred end of run.
They could do this for under a billion
If you wait for the second ph of ECLRT from Mt Dennis to the Airport, that might take a while & who knows when there gonna extend that Crosstown line west to Jane st.
We all know how you would have to climb a steep hill up to Weston then over a bridge ( rail way UP etc. ) which isn't wide enough then a narrow road way all the way up to the 401 past Church st. That would cost many millions to widen or tunnel up that route.
But hey if Metrolinx or John Tory can keep going with this ECLRT West ,
Have a connection @ Jane & Eglinton for the Jane Lrt north !
I'm all for it
Then Tunnel south to Bloor subway
Ph # 2
Then connect to the DRL ph 3
But I Think John Tory will have his Smart Track go to Mt Dennis.
Good luck with getting that route electrified & the trains won't fit in Union stn.
Many issues with this Dumb Track plan!
This will take many years and a lot of money to implement!
At least he has realized going west on Eglinton with full sized train was a pipe dream. Wonder what was in that pipe!
And You will Notice When DRL route is finalized. It will stay away from the ST plan & so be it also in the west.
well since it looks like DRL may be along Queen St then it will really make sense to have SmartTrack to hit union and go west to hit Bloor (Dundas west) and then Weston (Eglinton). Actually, we have the UPX already. It can become the Western route of SmartTrack so all that is needed is the eastern/north route. This way the line will serve the growing employment south of King its perfect There already is a city report on possibility of having the UPX be part of SmartTrack although of course Metrolinx has said its premature as the line was up and running in June 2015 and needs time to build the numbers. But once Crosstown hits the airport there really is no reason for the UPX not to become part of SmartTrack
I am sorry, I realized afterwards, wrong siteCan you please take this to the UPX or SmartTrack thread? We do not need to open this can of worms here and muck everything up.
You can simply delete the post and put it in the correct thread.I am sorry, I realized afterwards, wrong site
Is it lost on most Jane LRT backers that this would have to be built as a subway south of Wilson? I think after the TYSSE, Finch LRT and Crosstown open you'll see that the ridership of the 35/195 Jane will drop significantly, so much so as not to warrant anything beyond express bus service. LRT for Jane is overkill.
You have to look @ the big transit plan here , TTC & Metrolinx is finally moving ahead with getting some new modes of travel in a very congested city that uses Dated Diesel spewing Buses.Is it lost on most Jane LRT backers that this would have to be built as a subway south of Wilson? I think after the TYSSE, Finch LRT and Crosstown open you'll see that the ridership of the 35/195 Jane will drop significantly, so much so as not to warrant anything beyond express bus service. LRT for Jane is overkill.
