wopchop
Building Toronto
I believe I've seen the NextBus display at the lower level of the bus bay at Wilson station.
The next train displays aren't fancy, but they get the job done. I do kind of wish there were light up LED boards though. Not as technically advanced, but personally it is one of those 'less is more' things.
One thing which would be cool is to have information about multiple upcoming trains. That way if one is too crowded, you know when the one after (and after that) will be arriving.
In montreal, the displays show the next train and the one afterwards. Which I think is a good psychological reminder to people that it's not the end of the world if they can't sprint into the train before the doors close..
My suggestion is that either:
- schedules (or whatever it's called) be adjusted such that another driver takes over immediately when the bus pulls in, therefor limiting the time the bus is sitting at the station
- OR, have an LED sign above each bus in the bus bay showing # of minutes until departure
One suggestion I have:
When you're transferring from a subway to bus at a bus bay like at Eglinton, there's a display that shows you how long until the bus arrives. Great.
The problem is that once the bus is in the bay, you have no idea how long it will be until it actually leaves. It could be anywhere between 1-10 minutes. The driver is usually taking a break or (I'm guessing) waiting for the next scheduled trip time. If it's a long wait time it can be quite the travel time penalty.
Let's say you're heading to Eglinton & Bayview. You have multiple possible buses to use: Lawrence East, Eglinton East, Flemington, Leaside, Thorncliffe are all bus lines that you can use. However, since you don't know how long until each bus leaves, you choose randomly and if you choose wrong you're sitting on a stationary bus for a long time, watching other ones leave.
isDeparture (boolean) - For most stops predictions of when the bus will arrive are provided. But there are some stops, especially stops at the beginning of a trip, where there is a layover. This means that the bus is stopped for at least several minutes. For these situations the departure time is provided because a passenger is only interested in the departure time for such situations. Toronto TTC streetcars are an exception. At terminals arrival predictions are provided for TTC streetcars since they are managed more by headway instead of schedule. In order to specify whether a prediction is for a departure as opposed to an arrival time the additional tag element “isDeparture” is provided along with the predictions. If it is set to true then the prediction is for the departure time. Otherwise the prediction is for an arrival time. For departures NextBus uses the schedule to determine when the vehicle will be leaving the stop if the vehicle is on-time or running early. If the vehicle is running late then the departure time will be based on the vehicles arrival time (assuming that the vehicle will depart as soon as it arrives without any layover).
This is a good suggestion. I recall that as of a few months ago, the TTC planned to change the system to show how long it is until the bus departs. I can speak from experience that this has been implemented for the 7 Bathurst at Bathurst Station.
By the way, the NextBus API does provide estimated departure times to third party applications. Estimated departure times will typically be provided at route terminals, or anywhere where there usually are significant layovers. This feature has been immensely useful for me when using Transit App. I'm surprised that it's taking the TTC this long to implement it across the system.
See page 14 on the NextBus XML Feed documentation; isDeparture(bool):
It would be nice to see estimated departure times expanded to the streetcar system.
TTM, you took that idea straight out of my mind. I am very guilty of checking bus arrival times on my smartphone at every possible opportunity on the subway (even taking advantage of the TCONNECT Wi-Fi service, even if the train stopped at the station with Wi-Fi for no more than one minute) and this would be a great idea, especially for people who don't have a smartphone.I've suggested this in the past. Unfortunately, the LED dot matrix display on the TR is already cluttered with next station information and the four LCD screens on the trains are too small and, generally, too far away to be useful during rush hour.
If I'm remembering correctly, when the train is arriving at a station, the LED display is set up as such:
Next station is Eglinton.
Exit this side.
To get next bus information on the vehcile, I'd remove "exit this side", and keep the arrows indicating which side of the train the doors will open:
54A - East to Starspray - 11 minutes
100A - South to Broadview Station - 7 minutes
32C - West to Jane and Lawrence via Tretheway - 4 minutes
Etc...
Alternatively, the arrows could be replaced by an X or check mark, on the far left or right side of the displays, indicating which doors will open. This will allow for two surface routes to be shown at once, or for the current time to be shown.
I'd also install two addictional LED matrix displays per car, so each pair or doors will have a display.
When on the at-grade parts of the subway, I frequently see customers using their smartphones to check bus arrival times just before the train arrives at the station. For this reason I believe that this feature will be well appreciated by TTC riders.
