W. K. Lis
Superstar
The signs on the side of the T1 trains are operational.View attachment 134586
Two-colour (yellow and black). Lowest bidder.
Does it display on the inside, the same?
I rode the BYD demo that toured Ontario in 2015. Pretty peppy acceleration. It could keep up with traffic fine, but it was slow going up hills.How long until the electric buses come into service anyways? I’m eager to ride them.
Electric motors have instant torque, which should mean faster acceleration and a less sluggish ride
Not necessarily operational. They are still on this sporadic "testing" phase, and sadly this is essentially how the signs will look like when they are fully operational system wide on all trains.The signs on the side of the T1 trains are operational.
Not really as it is referred to that way. The subway and SRT are always referred to s Line 1, 2 3 or 4.It would make more sense if it was just
2 - Kipling
It was internal TTC work no contractor they probably just went to the company that makes the one for their buses and gave them the size they wanted. And on the inside, it says nothing it's just a piece of steel to support the sign.Two-colour (yellow and black). Lowest bidder.
When speaking, yes but people call it "route blah" when it comes to a bus, but nobody is confused that a bus destination sign doesn't write it out
It is also interesting that several of his ideas have already been dismissed by the TTC Board as being impractical or needing more study.John Tory announces he will back an amendment to the proposed City budget to add $3M to reduce TTC overcrowding.
This was part of a 10-point plan on said issue. The rest of which were mostly dismissable.
While the sum is paltry, its likely the best the TTC could make effective use of this year given fleet limitations for both streetcars and buses.
Its a welcome course correction. (a nearly identical motion to add 3M was defeated at budget ctte 2 weeks ago)
https://www.thestar.com/news/city_h...-10-point-plan-to-alleviate-ttc-crowding.html
So I guess the problem is worth $3M in his books. Compare and contrast how much moving heaven and earth he did for speeding up the Gardiner rebuild.
John Tory is the ultimate status-quo, and "just right" mayor. Everything he does revolves around those two principles. Nothing he's done over his tenure has been innovative or groundbreaking and time after time, he comes up with budgets in his own admission that are "just right".So I guess the problem is worth $3M in his books. Compare and contrast how much moving heaven and earth he did for speeding up the Gardiner rebuild.
