And it was David Gunn's insistence on not even saying what we should build if we had the money that kept us from starting anything meaningful until two terms into a Liberal government.
I remember at the tail end of that era being told, literally, "we don't talk about expansion since there's no money for it".
I got a suggestion... raise property taxes....
I live in Sudbury, and compared to us, you pay a lower rate. If you raised taxes, then you could afford it.
But, I know, I know, cutting services is more palatable than raising taxes.
I know it and you know it... it's just our local politicians claim we pay one of the highest tax rates around which is not true.
Honestly, it would be easier to levy a transit improvement tax of 50% on all purchasable goods.
It'd be easier to put a levy on everything, but, no, please, don't raise taxes.....
Lets not get into semantic debates. The only thing that really matters is that the Crosstown is a fully protected mass transit line. The line could be using horse drawn carriages for all I care
The difference between light rail and heavy rail and horse-drawn carriages is not purely semantic, especially in the context of a discussion the capacity of the TTC system to handle the ridership growth.
There was a Yonge Streetcar. I wonder why it got upgraded to a Subway.....
The big change between subway and streetcar on Yonge was grade separation, and stop spacing. Saying a mixed-traffic streetcar (which is effectively an upgraded bus) is the same as light rail running as part of a rapid transit system in a tunnel is disingenuous. Even in the case of the crosstown surface section, or finch, the stop spacing is greater than it is for the streetcars. If we'd replaced a tunnelled streetcar with a heavy rail subway, then you'd have a point.
Personally I've got half a mind to propose making the CEO of Metrolinx an elected position with some sort of taxation authority.
I don't disagree but division of revenue can run into issues. If Metrolinx gets someone with big plans combined with a spend-thrift premier (hiring freeze, capital freeze, etc.) would MTO demand payment for use of land allocated to them (such as the Highway 407 corridor) in order to float their own budget?
Before the 1940's, the "subway" plans were for an "underground streetcar" up Bay Street shifting over to under Yonge Street.
The first "subway" in North America was in Boston, in 1897, using streetcars. Today, that "subway" still exists and was and is being extended, but now they call them light rail vehicles.
See link.
It is all about the amount of people the line moves. Buses move less than streetcars. Streetcars move less than LRT. LRT moves less than Subways.
Just like having your neighbourhood served by a subway is not worth it, having a neighbourhood not served by a subway is a bad thing. Toronto needs more mass transit. As soon as 1 project completes one part, then, a new project does that part. For example, once one subway is tunneled, a new subway is tunneled, all while that first one has their stations built.
Probably worse than that. Bearing in mind the actual legislative structure, there would be no way to create an elected Metrolinx that a Premier couldn't just be rid of the moment it became inconvenient.
Grade-separating light rail like Eglinton-Crosstown could have allowed longer trains and more frequently without worry of disrupting on-street traffic, including pedestrian traffic. But since Eglinton-Crosstown will also have on-street sections, i.e. it is not full subway line, it will not be able to take advantage of that grade separation to increase capacity. They will still have to limit the size and frequency of the trains the same as an on-street light rail line, and therefore the capacity will still be the same as other modern light rail.
And of course, LRVs are much narrower compared to the subway trains. Even if the light rail trains are the same length, the capacity is still significantly lower.
The tunnel might be able to allow the Eglinton trains to operate faster than other light rail, so fewer trains need provide the same headway, so it will save money on operating costs. But the capacity of the line will always be constrained by the on-street sections. To use longer, wider, more frequent trains like a subway line, it would mean full grade-separation.
The Montréal Metro cars [2.51 m (8 ft 2 7⁄8 in)] are narrower than Toronto's streetcars [2.54 m (8 ft 4 in)], yet are considered a "subway". The Eglinton Crosstown LRT will be wider [2.65 m (8 ft 8 in)]than both the Toronto streetcars and Montréal Metro cars.
Except that the service is going to operate as two branches - one branch operating the full length of the service, and a second running only in the grade separated service between Mount Dennis and Laird. The capacity of the underground section will be quite a bit higher - by necessity - than the section built at-grade.
