If we look at Durham region and where the built up areas are, they are along the old Highway 2, the 401 and the LSE GO route. It is reasonable to assume that when Via is routed on the Havelock Sub, developers along that route will push the province to put in a GO train if they build subdivisions there. Chances are, it will take at least 10 years after Via opens that route before that happens.
You got lucky. One anecdotal trip evidence does not make.
I mean as someone who used to take VIA every month or so between Ottawa and Toronto, I can support what @Bojaxs is saying. When a delay happens, 75% of the time its past Pickering where the train has to wait for a GO train, and the other 15% or so of the time is there's some train from Montreal that's somehow an hour late blocking Brockville Junction.
How practical would it be for regional/commuter rail to also operate on potential HxR tracks? VIA HFR execs have been playing up the potential of cities like Peterborough and Trois-Rivieres to be part of the commuter shed of Toronto and Montreal respectively. However the likely cost of HxR tickets won't make it a viable option for most commuters.
Realistically if there is some sort of GO service built, I don't see it going any further than Locust Hill.
That's true, so I'm working on assembling actual data using the GPS traces fo Via trains that are publicly online.
In the meantime I'll also share my anecdotal experience from frequent travel between Toronto and Ottawa that Metrolinx generally causes far more minutes of delay per kilometre than CN.
Even if they could use Stouffville (which Smallspy is doubting), the Lakeshore East corridor is now constrained to four tracks between the Don and Pape, because of the Ontario Line. When it had a 6-track capacity before the Ontario Line was planned, one or two tracks for VIA was possible.
You can still take the Bala sub to the don branch to the Belleville Sub to Agincourt yard. You would need to build a bypass through the yard to use the Havelock sub Row.
The other way is to go to UXBRIDGE and use that rail corridor east. But it doesn't go to Peterborough.
Actually.....
...but seriously, reactivate the straighter line to Kawartha Lakes(Lindsey), then down to Peterborough. Thereby avoiding the CP yard and adding one more potential stop. This also means that no issues with freight operations.
Actually.....
That would get you to Perth where the Belleville Sub meets Highway 7. But it's probably an extra 100km. Which is nothing if you are travelling at 250kmph.
Actually.....
This potential route has a couple problems. It's roughly 25 km longer to get to Peterborough than the CP line. We just got through pages of talk of bypassing Ottawa to save that much distance yet again. Imagine bypassing one of the biggest destinations on the line and then adding it back to serve a town of 20,000. The mind boggles.
The other problem is that the right of way is long gone in both Lindsay and Peterborough. It ran down a city street in Peterborough so obviously those links aren't going to be rebuilt. The CP line, by contrast, is intact and operational through Havelock.
There was talk of finding a way to not be held up at the waterway. This could help with that option. TBH, there is no perfect option out there, but, this one could be a good option.
Do you mean the canal in Peterborough? I may have missed some messages.
Do you mean the canal in Peterborough? Taking a route through Lindsay doesn't solve that problem, the canal still has to be crossed. Plus it adds new problems of being a longer route that has significant gaps in it.
Yes, the canal.
Since they would not be relying on the existing route, they could build a raised bridge over it.
And through the middle of Lindsay (as well as Uxbridge).
Drawing lines on a fantasy map is easy.
Sounds much like what the last few pages have been. I offered something. I am ok with people helping me see where it would be a challenge. As it stands, there are no perfect options. There are many options, with each having their challenges. TBH I doubt any of us are privy to the final route and how it deals with the challenges of that choice. So, it is all speculation. Some would say a fantasy.
Yes, the canal.
Where? That former rail line (now a trail) ends at Bethune Street and isn't intact through downtown Peterborough. What are you proposing for it to get to the canal, let alone cross it? Lindsay has the same problem, although through a less dense area, plus the Scugog River is another branch of the Trent-Severn Waterway so you'd have to build a bridge there too. Plus it's a longer distance as I mentioned. Your solution just adds more problems.
