 6.4K     0
The RFQ was apparently released in 2018 and a cycling plan from that year (May 2018) was thankfully already posted a few months ago:
This cycling plan clearly shows a total of only 10 revenue Renaissance cars in service (8 Economy plus 2 Business) at any time of the week and if you compare the suitcase symbol (indicating checked baggage service) on Quebec-Montreal-Ottawa services in the PDF timetables between June 2015 and March 2020, you will notice that the Renaissance cycling shown below has been virtually unchanged over the last half-decade:
Therefore, unless you insist that there must be more than one spare set to back up for these two measly Renaissance sets, the total seat count you calculated shrinks by 720 seats (i.e. 15 Renaissance cars) from 9,536 to 8,816 seats...
Thanks for the information. I wasn't trying to insist anything, but was strictly relying on numbers VIA officially released, originally in their 2017 Corporate, and then later modified in their 2019 and 2020 presentations at the NGEC annual meetings. Not being an insider, I have no idea what VIA is actually doing, but one possibility is they used some creative accounting to allow them to enlarge the useable fleet by replacing equipment they aren't actively using.
I'm not aware of any serviceable Renaissance cars being currently located outside of Montreal, just like I'm not aware of any Renaissance trainsets having been in revenue service since train 24 arrived into Montreal on March 17 (i.e. the day the first Covid schedule came into effect) or of a second Renaissance trainset being in Corridor service after the blockades brought all Corridor operations to a standstill in mid-February (which, again, doesn’t exactly support the theory that most of the 30 Renaissance cars @roger1818 included in his seat counts are actually serviceable).
As I said, I am just reporting what VIA is publishing.
With Business class having less seats per row than Economy class and with a cab car in the fleet, the minimum number of coach configurations would still be 3 (unless you configure the cab car as the only Business class car).
Which is what I said.
If you don't have different Economy or Business non-cab car types, you would be forced to have accessible facilities (accessible washroom and two wheelchair spaces) as well as galleys in every single car, which would result in a lower seat count...
That makes sense. It is a bit of a trade-off. I guess the requirements/expectations for onboard facilities have chanced more recently.
b) does the capacity of a trainset allow VIA to deploy enough seats wherever there is demand, thus maximising net income and market share.
The second test is my worry.
I can’t shed my suspicion that Ottawa shorted VIA overall. VIa can only play the ball where it lies, and isn’t free to publicly articulate its initial proposal....I’m sure they will do their best, but I would have been happier if the new fleet had more trainsets and more seats, with VIA being given a mandate to go out and maximise its market share.
I get the concern. But I think it's a little exaggerated. VIA is fielding at least as much capacity as it has now. And has enough options to increase the fleet by 50%, irrespective of what happens with HFR. And given that most of these options usually have exercise terms required by end of the first orders delivery run, we know they have at least 3-4 years to place an additional order. Given that demand is likely to be suppressed for a few years, that timeline to exercise probably lines up.
They have time to get the trains into service. Learn what works operationally. And then petition the government for funding to exercise those options if they think they need the additional capacity. Not to mention getting a decision on HFR and, if approved, a timeline when they need that capacity.
The thing I don't understand is, what do you have against having any economy class coaches on the train you are travelling on?
You are assuming that I have something against economy class. I don't. Travel in it most of the time.
What I want is for VIA to succeed. And capturing a good part of the business travel market is something I think is necessary for that. The fact that business class fares are sometimes higher than airfare is what tells me they don't have enough business class seats. Either that or their yield management model is broken.
You see this as a zero sum game. Ie That a carriage can either be Economy or Business class. But that's not how any transportation business is actually run. It's run based on yield. Return for asset. If yield is too low, there's another option: not buy the coach/aircraft/etc. You seem to assume that VIA would increase Economy class seating if they reduce the number of business coaches. It's far more likely they would have ordered less business coaches to begin with.
VIA must clearly have a yield model that shows 2 business carriages on a 5-carriage train provides the best yield. Which is why they ordered what they did. If you want to argue that their business class seating is over-provisioned, I'll wait for you to put up your yield model to back up that assertion.
HFR is the key. If HFR is approved, and the option for the second order is triggered, then VIa will have all the seats it can use effectively.
If HFR isn’t a go, the number of seats in the fleet will be the least of our worries.
I will try and say it a different way to see if you can understand. It is based on what VIA says the trainset configurations they need are. If (I put it in bold for a reason) VIA receives 32 "long" trains (in other words 32 of each of the 5 different coach types), 40% (2/5) of their fleet will be business coaches. All other trainset configurations that VIA claims they want to use, require a lower percentage of business coaches (I am talking fleet utilization, not seat utilization based on what VIA says they want to do, not some pipe dream of what they could do).
TypePercent Business CoachesFraction
Extra short33.3%(1/3)
Short25.0%(1/4)
Long40.0%(2/5)
Extra long28.6%(2/7)
This is flawed analysis based around the fixation that the percentage of business class seating must be constant.
Like I said earlier, the markets are somewhat independent. On a given route/segment, they will have demand of xx business pax and yy economy passengers. They can (and will) have demand for different classes scale differently on different routes. But since coaches are a discrete value, that imposes the constraint that the minimum number of business coaches is 1. And they will add a second business coach at a certain demand and yield point. This is what leads them to have only one business coach on all the short configs. It's a minimum offering. And two on all the long configurations. It helps to conceptualize it as VIA having a baseline demand of 1 business carriage on all routes and a second business carriage on some routes.
I think of the configs more like this:
Extra short: minimum viable configuration for any service. Sub-3 hr routes.
Short: Regular economy demand. Low business class demand. Most likely on routes under 3 hrs (Ottawa-Montreal or Montreal-Quebec or all routes originating in Kingston).
Long: Regular economy demand. High business class demand. Most likely on highly frequent and higher premium routes (read TOM routes).
Extra Long: High economy demand. High business class demand. Same as TOM routes.
Absent HFR, I expect Corridor West will be all Short/Extra Short and Corridor East will be all Long/Extra Long. The only exception being services from Ottawa and Quebec City to Montreal which might be Short/Extra Short.
Post-HFR, I expect all Kingston hub and Montreal-Quebec trains to be Extra Short, all Corridor West trains to be Short. And all HFR trains to be Long/Extra Long.
Even without data, I don’t recall a time when anyone observed that VIA’s Business Class cars were consistently running empty, on any route or train. I suspect that VIA has quietly managed how many cars it has configured for Business, and which trains have them, in a very businesslike way.
I can easily imagine say the 16:00 train out of Toronto having two business class cars... with a demand pricing model that shifts the economy passengers towards an earlier or later train that has more coach seats. That’s one selling point of the high-frequency model, some travellers have precise expectations but others will adjust to when seats are available.
The fly in the ointment is only being able to adjust supply with the adjustment unit being an entire coach. Airlines have a lot more flexibility eg to change how many rows of premium legroom economy class they offer within the same airplane.
To grow the Business business, VIA first has to fill every seat in that first coach (they are probably well on their way) and then add a full second car. That second car will start at 10% full, and grow over time. Utilization as a statistic will fall - and may never recover on a single route or train. 60 of 60 seats sold today vs 100 of 120 seats in five years. There is a cost and a risk to that almost-empty second car. VIa will have to manage the threshold carefully... too conservative, they will turn away business, too aggressive, they will haul too many empty seats.
Somebody gets it!
The fact that pre-Covid, there were regularly days and specific departures when VIA One fares were higher than airfare means VIA has room to capture marketshare. They should be able to price a bit more aggressively against the airlines with two business carriages (though the absolute numbers of business seats isn't going up that substantially).
Heck, this is why I say that I could imagine a subfleet of say 3-4 all business class trains (with 3-4 business carriages each) operating express from Ottawa and Montreal to Toronto. Leave at morning peak, return run after lunch, and then back out at evening peak. But this would admittedly be quite the risky and bold undertaking for VIA.
Yep. When their unit size is ~40 seats, fine tuning that demand management gets clumsy, I'm sure.
And you are assuming that I have issues with there being 2 business coaches on a 5-coach train. I don't! Having 2 business coaches on a 5 coach train makes total sense to me. As do most of the other configurations. If anything, I don't think the 7 coach train has enough business coaches, but that is either a mistake or VIA knows something we don't.
This isn't about demand management. My concern is with fleet management. In case you don't know the difference:
  • Demand Management is making sure the trains have enough of the right type of coaches to meet the demand.
  • Fleet Management is making sure the fleet has enough of the right type of coaches to build the trains you need.
If VIA only buys standard 5 coach trains and uses them to build all the the lengths trains they say they want, they won't have enough coaches of certain types and too many of others to build all the trains they say they need to build.
As I said, I have no issues with the proposed trainset layouts. In general they makes sense.
I do question why the Extra Long (7 coach) layout doesn't have 3 business and 4 coach instead of 2 business and 5 coach, but maybe that is because of seasonal demand. I expect business class ridership is relatively consistent all year long, where as economy ridership is likely seasonal. As a result, some trains will seasonally transition from extra short to short and others will transition from long to extra long is likely a seasonal change. Almost never would a train transition from short to long.
I’m sure there was lengthy analysis and number crunching before the final decision of a mixture of x 3-car, y 5-car, etc was arrived at.
The decision being a government one, there was a challenge process where somebody (from Treasury Board and/or the Transport Ministry, not VIA) laid out arguments about how x seats in the current fleet could be replaced by x-y00 seats in the new fleet because better utilization, standard fleet, more reliability, not all current seats sell anyways etc. I expect it was a lively challenge with lots of back and forth explanation, exchange of data, reworking of assumptions, etc.
What we will never know is a) what VIA’s original ask might have been, and b) whether VIA agreed with (or managed to argue to a liveable compromise on) those assumptions, versus had a less favourable outcome forced upon them and c) whether the end result had a growth provision, and if so how much ?
That challenge process is standard diligence, every capital proposal runs a gauntlet from beancounters and controllers ....and I know I continually harp on “Ottawa“ as VIA’s least helpful friend. Grain of salt, is all I’m saying. VIA will do its best with what it was given.
Who says VIA is doing this?
Because economy demand scales faster than business class demand.
Or they can just resort to different schedules in different seasons. And run more trains in the summer. Breaking trains and rearranging them only makes sense if demand shifts regionally by season. That's not very likely in the Corridor.
What do you mean by "the 16:00 train out of Toronto?" Looking at the pre-COVID schedule, I don't see any trains out of Toronto at 16:00 (I also looked at their current COVID schedule just in case). The closest I see were trains 46 and 646 to Ottawa at at 15:40 and 16:35 respectively. AFIK, both of those trains already have 2 business coaches. I guess there is also train 83 to London at 16:35 Is that the train you are taking about?
Or do you mean a new departure? If so, what train would you cut to make room for this new one?
Also, by "2 business cars," do you mean adding a second business car or do you mean a train with only 2 business cars and no economy cars?
Nothing official but I was once privately told that 32 x 285 = 9,120. ;)
That makes sense.
Sure, they could do that, but seasonally cutting service is counter productive when you are trying to grow ridership.
I tend to disagree. Ridership does tend to peak around long weekends and holidays. Bad winter weather can also cause a spike in ridership, but that is harder to plan for. I suspect the summer months also has higher demand from tourists. I would be curious what @Urban Sky has to say about this though and if it would be worth seasonally shortening and lengthening the corridor trains.
Right. But what they buy nominally, especially announced in some presser, doesn't always line up with final delivery configurations or even how service is configured.
Which is why I said seasonal adjustment is not very likely.
Don't need to break trains or reconfigure for this. Just use pricing. The only time reconfig is needed is when they want to physically reallocate capacity from one part of the corridor to the other.
If all that happens is demand grows broadly in the summer or on weekends, they aren't going to be reconfiguring weekly. That can just be yield managed.
I was speaking generically - the point being any end-of-business-day timed train is likely to have a very high demand for business class. And if today is 2 business cars, then my comments related to adding a third.
Converting economy cars to business cars is probably revenue-enhancing, but I agree that shouldn’t lead to turning away coach customers. One would hope that if business grows, a followup order for more coaches to lengthen the initial trainsets would have a good business case. So long as the fleet starts out with some room for growth, justifying that add-on order because the fleet is full would be a nice problem to have.
- Apul
