 6.5K     0
Kingston Mayor Patterson's indications of 6 trains per day each for Kingston - Ottawa and Kingston - Montreal under HFR seem plausible, but I'm not convinced about the 12 trains per day Kingston - Toronto, particularly given the goal of reducing interference with CN.
The new HFR route from Toronto to Ottawa should be fast and frequent enough to capture the entirety of demand between the two cities themselves, so the only passenger demand in the Toronto-Kingston-Ottawa corridor will be the demand specifically to/from cities along the lakeshore. Although the present Kingston - Toronto ridership may indeed be double either of the two corridors, that's because it's the only corridor of the three which has practical service for intermediate communities, including early morning and late evening trains.
Here's what I think a plausible scenario could look like along the lakeshore corridor with 6 trains per day each to Ottawa and Montreal, and 8 trains per day to Toronto.
To enable efficient meets and turnbacks, Kingston Station should ideally be expanded to 3 tracks, though it is technically possible to run this schedule with 2 tracks and a crossover just west of the platforms.
The main driver of interference is not frequency, it's the average speed of the passenger trains you want to insert. Therefore, it's much easier to insert milk runs (like #48) than express trains (esp. the kind with ambitious end-to-end times). The only problem with milk runs is that many of the smaller stations have only one platform (which undermines operational flexibility), but that's something which can be fixed without investing enormous amounts.
Just a random observation, but one thing which strikes me about the frequencies offered by VIA (and also in your schedule) is how much higher they are for Cobourg (CA/CMA Rank #111 with a metropolitan population of 20,125 in 2020) than for neighboring Port Hope (Rank #121 with 17,731), despite the relatively small difference in size...
^Nice timetable work !
I would add a 23:15ish departure from Toronto to Kingston, providing connectivity for the later evening trains from Windsor/Kitchener/Niagara, and serving evening entertainment venues in Toronto. (Use a specialised trainset that can handle all the water flow from crying Leafs fans ;-) )
The main driver of interference is not frequency, it's the average speed of the passenger trains you want to insert. Therefore, it's much easier to insert milk runs (like #48) than express trains (esp. The kind with ambitious end-to-end times). The only problem with milk runs is that many of the smaller stations have only one platform, but that's something which can be fixed without investing enormous amounts.
Yes I know that reducing the speed differential between CN and VIA massively reduces conflicts given that the corridor is fully double tracked. I'm just thinking about how VIA will still need to pay track fees for all that Kingston-Toronto service, without any of the Ottawa-Toronto ridership to support it.
I just copied VIA's current semi-fast stopping pattern. The details of the timetable are not meaningful, it's just a rough concept to get a picture of the services which could run within the various segments throughout the day.
Eastbound timetables, January 2020:
Good points. I've been wondering too how they see 12 Kingston-Toronto trains. Even with Express trains, I have a hard time imagining the many trains being supportable.
I've always thought 12 trains was sort of guesstimate balancing both sides of service from Kingston, cause that's how many slots they'd need from CN.
Also, a good point. I've always thought it strange how people look at Coburg as so much bigger than Port Hope.
Really, when looking at these , I question the value of express services altogether. There's no way to bolster travel between these cities with skip stop service. Also, I've always wondered why express trains skip Guildwood. Oshawa and Union are substantially less convenient to the eastern GTA. Especially with transit. And I would think this would particularly be the case in 10-15 years when Eglinton East LRT connects at Guildwood.
I can see how, if there will be 12 trains arriving Kingston from Brockville, one would try to retain enough slots west of Kingston to match their arrivals with potential departures westwards. Doesn’t mean you have to use every slot, but better to retain what VIA has now than give it up and try to pry it back from CN later.
Really, when looking at these , I question the value of express services altogether. There's no way to bolster travel between these cities.
With continuing densification, It’s not inconceivable that Cobourg/Port Hope/Newcastle/Bowmanville/Oshawa/Toronto could justify regional trains some day. Maybe those extra slots would come in handy then.
@reaperexpress Must say that the schedules between Toronto and Montreal are not good. Though day trips are clearly out, having no departures after ca 16.30 is terrible and means it is not easy to attend a meeting and get back home that night.
Don’t forget, later through passengers will take the north line out of Toronto. That slot exists mostly to collect through passengers from points further east. 19:00 is likely late enough out of Kingston.
Montreal doesn’t have as many (any, so far) connections eastwards, so a 21:40 arrival may be acceptable. A question would be how the arrival times in Montreal might line up to late evening departures to Quebec City.
I’m not hot on the 4 hour gap westwards out of Kingston at mid day. I might put the 10:40 departure out of Ottawa a little earlier and connect it to the turnback of the laying-over 23:15 train I suggested. That’s One more pair west of Kingston to improve the headway a bit.
Yeah I don't see how those communities could support 12 Kingston-Toronto trains either. But if there were 12 trains, here's what I would do with them:
I figured that to avoid redundancy, the extra trips would be used to increase the variety of stopping patterns. I also threw in a couple super-express trips for the benefit of Toronto, Kingston, Cornwall and Montreal travellers, on the basis that the lakeshore route is probably time-competive with the HFR route due to its shorter distance. So during the busier times of day, the "ICE" trips provide extra capacity to siphon a bit of Toronto-Montreal demand off the HFR route to leave room for customers to/from Ottawa.
From an operations perspective it's far easier to stop trains at Cobourg because it has 3 platforms, while Port Hope only has 1. So to serve Port Hope, trains may need to cross over to the other track, massively increasing conflicts with other trains.
The station access is also terrible, there isn't even a sidewalk.
Port Hope
Cobourg
Guildwood has pretty poor connections, actually. The only transit access is the buses which happen to pass by along Kingston Rd, which are still 200m away from the station itself. And those aren't even regional buses.
The bus services at Oshawa have much more significant catchment, being a primary hub for Oshawa DRT buses, as well as GO buses travelling across the GTA along both the 401 corridor (Pickering, UTSC, STC, York Mills, Yorkdale) and 407 corridor (UOIT, Unionville, RHC, 407).
I wondered about truncating those Ottawa trips at Brockville rather than Kingston to avoid using the CN line at all, but I decided against it since the timed transfer in Kingston means that they would be running right next to another VIA trip anyway. So the net impact on CN would be negligible, it would basically be one slightly-longer VIA slot. In contrast, if those trips continued to Toronto, you'd probably want to spread them out more to improve the effective frequency, or have one of them run express to improve speed. Either way the impact on CN would be far greater than what I showed in my earlier 8-train schedule.
The schedule between Montreal and Toronto is irrelevant because nearly all Toronto-Montreal service would be via the HFR route which is not shown.
They do realize that via rail is not a commuter rail system, right???
Commuter Rail is a term which is more centered on operational than commercial characteristics. The trip behaviors of passengers on early-morning trains like #20, #22 (between FALL and MTRL), #33 (between QBEC and MTRL), #51 (between MTRL and OTTW), #82 and #650 will look much more similar to that of the ridership on GO trains than to what you will find on mid-day departures like #64, #65 or #73...
The coach seating is configured to be fixed, and facing in one direction.
Perhaps you didn't ride them shortly after they entered service. Perhaps you don't remember how they were configured.
But they weren't built in the way that they are operated today.
Are those
Looks like they got wrapped or repainted while not being used and got new VIA stickers.
Im surprised why hardly anyone else in the western world has not adopted swivel seating like the japanese trains. That way everyone can all face the direction of travel back and forth. Its not rocket science and if the shinkansen can implement them safely its should be no issue on much slower venture cars.
As far as I know, all of the modern (2000 and more recent) Shinkansen trains use power swivelling. Not manual. A staff member can turn all of the seats in the matter of a minute via a control panel at one end of the car.
There may be a weight penalty to doing it. There is certainly a cost one. Both of these reasons may be why others don't do it.
