reaperexpress
Senior Member
The north mainline is definitely promising for medium-distance travel, but based on the penny-pinching rhetoric coming from Metrolinx's latest GO Expansion announcements it's safe to assume they will spend just enough on the line between Kitchener and Bramalea to accommodate the planned GO service, and not a penny more. There definitely won't be spare capacity available for Via.TRTO-LNDN via the Guelph Sub is only 10 km (or 5.5%) longer than via the Dundas Sub (195 vs. 185 km) and hits the relevant cities (Brampton, Guelph, Kitchener) rather than avoiding them (Hamilton). Once Metrolinx has figured out a way to sneak somewhat frequent passenger trains past Georgetown, it will be an absolute nobrainer to use the Northern route for intercity trains into SWO…
Ideally Metrolinx and Via should be collaborating to create an effective passenger rail system in southern Ontario that improves both regional rail (GO) and intercity rail (Via), rather than ignoring improvements to the latter. But in this particular case I think it does make sense for GO to fully take the Toronto-Kitchener-London corridor over. Toronto-Kitchener express trains can be extended to London without any impact on capacity on the CN mainline between Bramalea and Georgetown, or the single-tracked GO line between Georgetown and Kitchener. Via could affordably expand capacity on the south mainline by adding second platforms at stations, enabling them to use the double track that already exists rather than being bottlenecked onto the single platforms at Ingersoll, Woodstock and Brantford stations. That would enable them to add a couple trains per day, with service via Brantford to both Sarnia and Windsor.
You've already seen the content of my article on the case for GO Transit taking an increased role in intercity rail in Ontario, but I'll link it here again for others' reference:
https://ontariotrafficman.wordpress.com/2024/05/26/the-case-for-regional-express-trains-in-ontario/
