Staging *something* along the corridor seems intuitively smart, yes.
But I would question whether crews can be staged in a useful way. VIA has to schedule people to maximise the amount of work they do within the very strict hours of work rules imposed by Ottawa. Adding contingency time to shifts would lower productivity. Having crews staged at midpoints would not work, as they would be conspicuously idle 95% of the time. And, when they are needed, weather and other factors might mean they couldn't reach the scene of the problem. Having crews "time out" on hours is hard to avoid when delays happen given their fairly tight scheduling.
The same is true of trains - VIA's need to cycle trainsets productively means that any delay cascades, as clearly happened recently.
Rapid-response of standby trains and spare board personnel from the existing terminals is possible, but the same productivity issues arise and travel time to the problem would still be problemmatic - if, indeed, a standby train could thread the needle thru blocked freight and passenger trains to reach the problem. Once you have a standby train, maybe it's better deployed to fill in whatever gap in the cycling the non-availability of the stranded train creates.
Is it better to have two crews do a half day rather than one do a full day and the other be on standby?
It is better still to have everyone do a full day's work. VIA can't afford a crew of two being paid to do nothing on the off chance that a train will exceed its hours once in a while.
To the best of my knowledge VIA does not have extra board workers sitting awaiting work at full pay (I know of transit propertiesthat do schedule spare board operators who sit in the lunchroom until needed). The standard "spare board" call requirement is to report two hours after they are called. VIA might have personnel at rest at away terminals who could report faster, but their availability would depend where they are in their rest hours regime at the time of the need.
(This sort of issue is why as a management guy I had a very healthy respect for unions and elected union reps. The question of who gets the idle hours would be very divisive in any bargaining unit. Union reps are elected, after all )
  • Like
Reactions: PL1
So if the spare crews is in Ottawa and the train runs out of hours in Kingston they have 2 hours to report to Ottawa and then travel 2 hours (4 hours in a snow storm) to Kingston to relieve the crew that ran out of hours? Hopefully they would have taken pre-emptive action and called the spare crew before they ran out of hours since that would mean at least a 6 hour delay for passengers.
Give. That every revenue run takes at least 2 hours, it’s impossible to fit two round-trips into the maximum work hour limit of 12 hours - or to fit one round-trip into a half-day. A half-day almost inevitably means that it starts and ends in different cities, which implies a hotel stay before or after that work day…
Locomotive engineers have a locker at their home depot (e.g., MMC for Montreal-based and TMC for Toronto-based crews), but I imagine they can be dispatched directly by taxi to save time when rescuing a train.
The second you’ve called a LE for for duty, his shift legally starts with an already determined shift expiration time and rest-hours required after the end of his shift. There is a high cost of calling an LE you could have otherwise let work the following day, so preemptively calling replacement crews might bite you into the butt when a different LE calls sick the next day. Same reason why local bus companies will be reluctant to commit ad-hoc buses and drivers to meet stranded VIA trains and pick up their passengers…
Have You worked in a union environment? Would operating rules even allow on-board crews to do that? I'm not sure we even know what the exact problem was. Somebody mentioned a coupler. I have no clue about the couplers used by the Siemens but a lot of the proprietary ones include data/comms connections. Not a great place for heat.
I have worked in both union and non union places. I know that under no circumstances can I touch certain things no matter what. I also know how much I could touch under certain circumstances before I would be in trouble(and potentially not working there anymore)..Friend of mine works for CN as a conductor/engineer. They are expected to swap out bad knuckles on the spot. So,my thinking is, if it is a frozen knuckle/pin/fastener, that should be fine.
The average merchant or military vessel has a lot more resources on board to deal with some types of failures or problems than a Venture train does. But even ships have to call for a tow under certain circumstances.
A source has suggested that there was an unforeseen incompatibility between the two Venture sets involved. Maybe it wasn't just a frozen pipe after all. Just inside gossip, but quite credible.
If it was frozen something....having seen what gets done in freezing cold.... applying heat is what you do if you have sufficient time and patience and pure optimism and no other options to suggest and nothing left to lose. Asking a crew with minimal equipment and with defined hours of work to succeed by doing that, while their hours clock is ticking and they have a hundred miles yet to run before it expires, is a different matter. Sometimes cold wins.
I have been dragged back into Hawaii on one of our RCN ships. Mind you, that's because it needed a new engine room.
This incident still shows that the railways get surprised by winter every year.
There are two Siemens venture sets laying over in the Bathurst yeard. I guess it was easier than detouring to TMC. Can they service the washrooms from there?
They were iding so I guess there is only Shore power for GO trains.
Why would CN do this? They've hung their hat on the US experience and White Paper and used it to justify their speed reductions in Canada. Plus that policy is what's driven Amtrak to adopt OSEs through an FRA exemption. And we ALWAYS follow the States!
If we always followed the States, we would allow passenger rail operators to use EU rolling stock like they do via Alternative Compliance. But we don't. So the Stadler KISS EMUs they use in California on mainlines shared with freight could not be used in Canada on mainlines shared with freight. Ottawa's Stadler FLIRT DMUs operate under a TC waiver, whereas the FLIRT DMUs in Redlands CA, Ft Worth TX, Dallas TX operate under general FRA rules.
Any VIA CEO is going to be a political appointee and thus subject to political winds. It's worth remembering that the last CEO, Garneau, also left early when it was clear that VIA was being cut out of the HSR project, and will ultimately surrender the legacy corridor services. Not a good job opportunity for someone who is ambitious and wants to aggressively build a business..... but perfect pre retirement job for somebody who can just keep the seat warm and keep VIA below thecradar screen.
I was a bit surprised by the negative tone of CBC's report on his departure. It's a bit rich blaming VIA for allegedly high fares, when its mandate from Ottawa is all about reducing aubsidy. I wasn't aware that VIA's reputation was in the soup generally. Personally I think they are performing well considering the lack of support they are getting. VIA is a Cinderella story, fed a starvation diet and ignored by the family it depends on. Or maybe Oliver Twist is the better analogy.
I also wondered if Peloquin was being thrown under the bus for his handling of the Venture procurement, the disputes with CN, the slow service which is attributable to CN not VIA, and the cold weather issues - all of which the government appears more interested in burying than in solving. Maybe Peloquin simply isn't interested in a prolonged fight with one hand behind his back and Ottawa simply wants VIA moved off the front pages, without much commitment to actually delivering good transportation. Retirement may look pretty attractive after 41 years.
So I'm giving the guy the benefit of the doubt and wishing him a happy retirement. He has a strong CV and will likely stay active.
It seems like they can't keep a leader for even their term. I wonder if it's because he got a job that pays more elsewhere or gives you a glimpse of what's going on in the background?
OR maybe it has to do with the recent delays and passengers getting stranded.
The signals I'm receiving from my former colleagues indicate that his departure was neither voluntary nor unexpected.
I'm just wondering who would possibly want such an unattractive ejector seat where the federal government habitually blames you for their own failures...
It depends on your perspective. Afaik, the airlines don't come anywhere near the subsidy that Via gets. By starvation do you mean the government not buying up the ROWs? Not owning most of the rails makes Via frequently delayed. The schedule is more like a suggestion. IMO Via is also in a vicious cycle, they don't operate at an efficient scale, they don't have ROWs, so they always appear to be asking for government handouts. The Canadian government has just never invested in passenger rail in decades as European governments have for example. They built billions worth of ROWs for passenger rail, whereas Via is on its knees in front of CN just to function.
I'm sure he got a good package. 😁
I am tired of hearing airlines whinging about how high user fees (which recover operating costs, and not financing costs or amortization) are making air travel noncompetitive. Even the airport rents collected (which perhaps Ottawa should indeed fund in some other way) amount to about five cents per ticket sold.
I am quite content that the VIA corridor be made to run in the black on a framework comparable to full-recovery air fees.... but compare how much effort Ottawa puts into enhancing air capacity and effectiveness to how much policy effort they expend to enable VIA corridor service (ie, none....where's that Kingston hub, for instance ?)
As to VIA Remote and Transcontinental services, yes they are subsidized....but this market does not adversely impact air travel and might not even add air revenue if it was cancelled. Ridership on a biweekly Canadian or Ocean hardly fills a single 787 twice a week. Find me a pilot who considers the Churchill train a loss in business to their airline. The non-corridor services have no intersection with air or rail corridor economics and don't belong in the comparison.
Alto is a great step forward for Canada, but it is a future promise ie a squirrel that the pols are using to shift attention away from how badly they are managing the rail corridor today. In some ways, it's an admission that they have given up on VIA ALTOgether. Air travel can raise capital on a business case basis....Via can't. The pols and the absence of legal mandate prevent that. Sounds like Cinderella not going to the ball to me.
My thoughts are the more I learn how Via works, the less attractive a senior position looks in general. At least with the CBC and Canada Post, you have options and methods to do what is best for a crown corporation. For instance, why is there not a way to buy Via merchandise? Yes, I know of the stuff for the Ocean and Canadian anniversary.. But, what about other things? I can list things outside of clothing that Via could sell that would sell. Canada Post and the CBC have better stores.
