 9.3K     0
 5.3K     0
Photo taken May 16. 2021:
Foam Flower, a native plant, in Taylor Creek Park (not yet in bloom)
Also, I showed Blue Cohosh above, just as it comes out in spring, a dark purple colour; this is that same plant, in leaf now:
As I was passing along the bridge over Rosedale Valley Road yesterday, I saw something many of you might not see all that often; though it happens in forests with some regularity.
In the photo below you will see this tree is being harassed..........and in fact killed the vine that is all over it.
The vine is a native plant........its wild grape. As grape climbs the trees, the leaves of the grape actually shade the leaves of the tree, cutting off its ability to photosynthesize properly.
As the tree weakens, the weight of the grape vines eventually pulls it over.
It needs to be said that this is a natural process; and grape doesn't take down whole forests; though it can sometimes wreak havoc over a decent sized chunk of land.
Here is a close up of the grape leaves on this tree:
I hate that stuff! When we bought our small farm, it had been let go for several years and the vines had really latched onto some trees. It is not particularly selective but seemed to favour cherry and some conifers. I spend many hours trying to rip it out - including using the tractor, but sometimes if it was well established in the tree it was impossible and, even if I could, the tree was often badly misshapened. The vine is incredibly strong, particularly when it get to about an inch or so in diameter. The military should really latch onto this stuff!
@DSC 's good friend 'The Fixer' just wrote one of his silliest columns ever...............
Trying to spark mass panic about Cow Parsnip.
This plant, which is native, looks similar to Giant Hogweed, over which there is similar hyperbole.
The idea that if you barely rub up against the plant you face extreme danger is so unreasonable as to be comical.
Its certainly not impossible you may get an adverse reaction; but severe outcomes are very, very rare.
Toronto's natural areas are filled with a variety of plants more likely to cause you problems.
I dare not list them for fear 'The Fixer' will want 20% of the plants in Toronto removed.
I want to be clear, I am very sympathetic to people who have faced the most serious outcomes from assorted plant interactions.
In the case of Wild Parsnip/Cow Parsnip or Giant Hogweed the reactions in worst cases can be very serious. The severe outcomes arise out of getting the sap
that is inside the plant, on your skin; and then going exposing, your unwashed skin to the sun. (2nd degree chemical burns, and possibly, if you get it in your eyes, blindness)
Its horrible, and I wouldn't wish it on anyone. But if you wanted to eradicate all the plants that could cause you serious harm, you'd have to wipe out dozens of native species.
I wouldn't go so far as to suggest that simply brushing up against Cow Parsnip is risk-free; but in most circumstances, its fairly close.
Its the sap inside the plant that is a serious risk.
Typically, you would only be exposed to that if you broke the plant open, or fell on it.
At any rate.........
I couldn't begin to list every plant that could harm by means of exposure or ingestion.........
But I hope no one tells the Fixer about Poison Ivy, or Poison Sumac or Poison Oak, or Virginia Creeper or Wisteria, or Water Hemlock or...... you get the idea.....
PS; while most of us, myself included, will not follow good guidance all the time; it really is wise, if hiking into a natural area, where some contact with plants is to be expected ( narrow foot path etc), wear pants, wear long sleeves; don't touch what you can't identify.
In most cases, not following that guidance won't get you in trouble...........but sometimes.........it will.
I wouldn't go so far as to suggestion that simply brushing up against Cow Parsnip is risk-free; but in most circumstances, its fairly close.
And shoes (not sandals).
For many, nature is to be feared and controlled.
Spring in action in Toronto's ravines, w/nature coming to life.
Photos taken April 16-20, 2022:
Bloodroot about to flower:
Bloodroot in Flower
An Ostrich Fern beginning to stretch out:
First Trillium I've seen on its way up, no flower just yet....
Blue Cohosh emerging:
Finally, some Wild Leeks (ramps)
A couple of shots of Wild Plants from travels in Toronto's ravines this week:
Wild Ginger having a good year:
Some Wild Leek slowly forming a colony (the big leaves), but having to duke it out w/the non-native, invasive Garlic Mustard (all the small leaves close to the ground):
A shot of Virginia Waterleaf in the foreground, May Apple and then Blood Root in the background:
A good article in the Globe and Mail on Phragmites, a highly invasive species of reed from Europe that has been taking over wetlands, drainage ditches and more throughout Southern Ontario for years.
The article comes on the heels of the province announcing 16M over 3 years to manage the problem; and problem estimated in a 2019 report to require 90M per year for several years for an effective strategy.
This is a common problem, Ontario could far more effectively manage all invasive species by investing something closer to 1B per year, probably for a decade or so, and then largely wiping out all that damage, and restoring native landscapes. Eventually a much lower sum could be spent, preventing re-establishment of problem species.
By under spending, we allow the problem to spread/worsen, or at best stabilize.
@Northern Light I didn't know this thread even existed. I felt like this was the most appropriate thread to talk about responding to wild plants.
Although I am not particularly keen on flora like you are, I went to Evergreen Brickworks Park back on June 26, as the City was deploying goats to graze on wild plants in the area. Here are a couple of photos I took when I was there:
Compared to other livestock animals, goats are more capable of consuming wild plants, and are used to control their spread.
It's something I don't know much about, but I saw this website on invasive species -- mostly plants, insects, and fish -- in Ontario.
https://www.invasivespeciescentre.ca/
I had also never heard of this large project in Simcoe County that involved removing non-native plant species and replacing with native ones, mostly to create a specific habitat for an endangered bird and other rare species.
