Albertasaurus
Active Member
Whoa that's going up fast!
Just the way Terry Wong likes it...Man does Chinatown have a lot of parking lots
Are those pallets of brick?
It looks like bricks for the back firewall break between this and the building behind.Are those pallets of brick?
Plywood is better than OSB?Curious why they are using plywood sheathing instead of OSB...
Oh that makes sense. They look bigger than regular bricks.It looks like bricks for the back firewall break between this and the building behind.
Occasionally OSB becomes more expensive than plywood and so plywood gets used. I remember seeing plywood being used in SFH construction about 10 years ago and that was the reason.Plywood is better than OSB?
Likely concrete block for the fire rating.Are those pallets of brick?
It is better in terms of shear (torsional stiffness) but usually costs more too.Plywood is better than OSB?
I hate to be that person, but shear and torsion are very different. But you're right, plywood is better in shear than OSB.Likely concrete block for the fire rating.
