And I showed you wrong. What a shocker.
Actually, the report states the maximum observed maximum volume was 4,500 at Lees, and 4,700 at Tunney's... Both stations that are on the grade separated portion of the transitway. Lord knows how much lower the capacity really is in the core. I actually wish these guys did research on the core curbside lanes too.
The writers of the report believe that the actual maximum volume may fall between 3,000-5,000 at Lees, and Tunney's Pasture stations.
I understand your incredulity, but BRT is a superior mode to LRT for longer disance trips, in all aspects except for the number of required drivers (which is almost a negligible point in this context). I was amazed when I first visited Bogota, Colombia and my jaw dropped when I read about the capacities - the most recent figure is *45,000 ppdpd.* The experience shaped my life and why I'm a self-professed transit advocate:
2007 figures (completed phase II) used in the BRT Planning guide - see Annex 1 system comparisons. If you have time, the whole guide is very interesting. Bogota is for now pretty much international best-practices in BRT.
http://www.itdp.org/index.php/micros...lanning_guide/
2006 figures (nearly complete phase II): page ix of
http://www.trb.org/news/blurb_detail.asp?id=6340
2005 figures - see the ppt 1.2 "Introduction to BRT", see the 6th to last slide.
http://www.uncrd.or.jp/env/est/news-BRT-nov05.htm
The system is also earning the city an estimated 25 million USD dollars in Carbon credits for reducing carbon emissions.
http://www.c40cities.org/bestpractic...bogota_bus.jsp And this has even garnered mention along with Curitiba in the IPCC third report on Climate Change Mitigation Ch. 5 page 332)
http://www.ipcc.ch/pdf/assessment-re...g3-chapter5.pd
How it Works
1) they run *2* lanes in each direction, with inside lane is routes that stop at every station, and the outside lane is used for routes that skip most stations and only stop at some stations (
the most popular & crowded)
2) Ridiculously high frequencies - the busiest stations have a bus arriving every 13 seconds during peak hours. Note that the stations are quite compact too - they are all fit in the median.
3) Fast boarding/offboarding - the average duration of a bus at a station from door open to door close is 24 seconds
4) Bogota is very dense - at 270 ppl per hectare, has city-wide density slightly higher than *central* Paris (or the fabled west end of Vancouver). That puts a lot people walking distance to lines. Imagine Finch West, Sheppard East, Jane or Don Mills with one of these. It's all in one's optics whether bus transit is inferior to rails when initial and O&M costs for the former can be remarkably more affordable.
And you continually overstate the value of BRT, due to you inherent bias against (ignorance of?) LRT. The article proved me right, you just read it wrong. Or do not want to admit your wrong. The fact your SOS group's "Move Toronto" contains only subways, and bus lanes shows you cannot grasp the role surface LRT can play in providing the intermediate capacity role needed in a transit network.
The largest light rail vehicles are about 10-15% larger in capacity than the largest buses, with a much lower percentage seated. By the time you actually do get to the scale where LRT requires less drivers, you enter the realm of heavy rail, and you require much much greater densities in order to support it. I think a system that offers services that are 10 - 15 mins frequency is useless here (it will lose out to people who will just drive every time). That's why the 190 isn't as heavily utilized as it should be, because of the prolonged waittimes.
By all means if you can consider a system like BART light rail than it starts to show some of the advantages of light rail. Most people when they mention light rail tend to think of much lighter systems that are generally pretty crap, while at the same time also thinking of some pretty bad BRT examples (there are quite a few that are indeed a joke and give it a bad name, or are simply only suitable for very low densities).
