Undead
Edit: I misread the diagram because it's looking east. Let me take another look. Still not a fan. Two rights is nuts.
UPDATE:Now for something NOT so good.
The City and Ports Toronto are doing major (and much needed) repairs to the bascule bridge on Cherry Street. Last year they completed the western half, this year it is the east side and they have just closed the Martin Goodman trail (or re-routed it). Unfortunately, their temporary (for 8+ months) solution is to have cyclists (and pedestrians) going south to continue to cross Polson Street just south of the new bridge and then immediately cross Cherry to get to the east side (as previously) - both with lights. Then you continue south on Cherry for ca 300 meters until the bascule bridge where everyone is forced to cross Cherry again, go over the bridge on the west side and the cross back to the east side of Cherry. These two crossings are poorly marked, narrow and dangerous.
I just wrote and asked why they do not build a temporary trail on WEST side of Cherry from Polson to south of the bascule bridge. If/when I hear something I will report.
I copied Councillor Fletcher and others may want to discuss with cycling groups - it is VERY dangerous!
Hi all, longtime reader and first time poster.
I've wondered if people more knowledgeable than me have ever discussed the idea of an east end railpath that follows the Lakeshore east GO corridor? I'm aware of the trail network in the Don Valley and some of the ongoing work there to extend into Scarborough, but I'm thinking of something analogous to the railpath on the west end that hugs the rail line.
Are there obvious obstacles to this? Has inclusion of a cycling path ever come up in plans for the Ontario line and quad-tracking work? Is the right of way wide enough? In theory it could give several neighbourhoods between the future East Harbour site and Danforth station (or beyond) access to an unobstructed route into downtown.
I didn't find any previous info on this topic after a cursory search. Apologies if I missed something.
They started moving the bike lanes on Adelaide last night from Bathurst to Portland. (Sorry for my bad pics)
They were pouring more concrete at Parliament Street side today and it looks to me as though they are not removing the existing asphalt (from the ex-Green P lot) though may perhaps add a new layer on top of it. I assume it WILL all be finished sometime next week.The work on the section of the new bike route through Parliament Square Park (the link between The Esplanade and Mill St) is moving along pretty fast. The Hahn Place (west) side is almost finished, the Parliament St (east) side has already been excavated.
It looks to me as though it will be fully open before next weekend. GOOD WORK!!
The promised landscaping is finished (and looks good too). The new path from Cherry/Unwin to the Sports Field is now open at least unofficially. My partner and I biked it today and it is a nice 'diversion'. I assume they will paint a centre line but apart from that, it's done!Over the last few weeks, someone has been doing work at Cherry and Unwin and it appears to be a NEW BIKE TRACK linking the Martin Goodman Trail to the Cherry Street Sports Field. Working west (Unwin & Cherry)
East (Sports Fields)
NOTE TO MODS: This thread seems to be used for any bike track talk - maybe change thread title to Cycling Infrastructure Bike Lanes - general ????
Ontario defines an ebike as such:The Provincial definition of e-bicycle is at https://www.ontario.ca/page/riding-e-bike#:~:text=You can ride your e,or the Kitchener-Waterloo Expressway
Not sure how to improve it but there is clearly a problem as some are FAR too fast, far too heavy and cannot (really) be pedaled. Perhaps someone here has a better definition and, if so, I assume Caroline Mulroney reads UT so maybe the situation can be clarified.
Roadway (vehicle lanes) | Bicycle Lane (painted only) | Cycle Track (separated, eg. curbs, planters, etc) | Multi-use Trails and Paths (includes pedestrians, joggers, etc) | Sidewalks | |
Bicycle![]() | Yes | Yes | Yes | Yes | No |
E-bike requiring pedaling (“pedelecs” under 40 kg) ![]() | Yes | Yes | Yes | Yes | No |
E-bike requiring pedaling (“pedelecs” over 40 kg) ![]() | Yes | Yes | Yes | No | No |
Power-assisted E-bike (max. 120 kg, max. speed 32 km/hr) ![]() | Yes | Yes | No | No | No |
Motorcycles, Mopeds, Motor Scooters![]() | Yes | No | No | No | No |
Yes, this is useful but, as noted above by @afransen there is 'confusion' and/or total lack of enforcement. The confusion can MAYBE be addressed by publicity, the enforcement is an ongoing problem!Ontario defines an ebike as such:
E-bikes in Ontario must have:
- a maximum assisted speed of 32 km/h
- a maximum weight of 120 kg (includes the weight of the bike and battery)
- an electric motor not exceeding 500 watts
- no modifications to the motor to allow it to exceed a power output greater than 500 watts and an assisted speed greater than 32 km/h
- battery and electric motor securely fastened to the bicycle frame to prevent them from moving while the e-bike is operating
- all electrical terminals properly insulated
- minimum wheel width of 35 mm and minimum diameter of 350 mm
- two independent braking systems that applies force to each wheel and is capable of bringing the e-bike, while being operated at a speed of 30 km/h, to a full stop within 9 metres, on a level asphalt surface, from the point at which the brakes were applied
Anything outside of this is not an ebike but a motorized vehicle.
However in Toronto specifically, they have made a distinction between an e-bike and a pedalec.
Electric Bicycles (E-Bikes) & E-Scooters
www.toronto.ca
Types of E-bikes
pedelec & pedal-assisted cargo E-bikes![]()
Pedal-assisted (“pedelecs”) are e-bikes requiring pedaling for propulsion (i.e., the power is cut to the motor when the rider stops pedaling). These are treated like bicycles in the Toronto Municipal Code if they weigh less than 40kg and require pedaling for propulsion, and may be used on roads and all types of cycling infrastructure: painted bicycle lanes, cycle tracks (separated bike lanes) and multi-use trails and paths.
Pedal-assisted cargo cycles are legal for use in Toronto on roads, painted bike lanes and cycle tracks.
Power-assisted (throttle only)![]()
Power-assisted are E-bikes that are capable of being propelled solely by its electric motor (throttle only). Power-assisted E-bikes may be bicycle-style, scooter-style or moped-style and regardless of style of appearance, they do not require any muscular power or pedaling for propulsion.
Power-assisted E-bikes are not allowed on cycle tracks (separated bike lanes) or multi-use trails or paths, because they pose safety risks when mixing with slower, human-powered modes like bicycles. It is also difficult and risky for such E-bikes to exit cycle tracks which can have raised curbs or vertical elements (e.g., posts, planters, etc.) when passing slower cyclists, whereas painted bike lanes do not present such issues.
For more information, please visit the Ontario Ministry of Transportation’s page on E-bikes![]()
Toronto City Council adopted 2014 Decision on electric bikes. In a 2014 report adopted by Toronto City Council, power-assisted bicycles are considered similar to scooters and mopeds, and called “E-scooters” (not to be confused with standing electric kick-scooters which are also called E-scooters).
And that affects where you can ride them
Where you can ride an E-bike in Toronto
Roadway
(vehicle lanes)Bicycle Lane
(painted only)Cycle Track
(separated, eg. curbs, planters, etc)Multi-use Trails and Paths
(includes pedestrians, joggers, etc)Sidewalks Bicycle
Yes Yes Yes Yes No E-bike requiring pedaling
(“pedelecs” over 40 kg)![]()
Yes Yes Yes No No Power-assisted E-bike
(max. 120 kg, max. speed 32 km/hr)![]()
Yes Yes No No No Motorcycles, Mopeds, Motor Scooters
Yes No No No No
