scarberiankhatru
Growth will not switch to Kennedy & Eglinton, nor should it. STC has a mall and that trumps absolutely everything else.
Why would it even be $300 million per km?? They could just expropriate some industrial lands and build the subway in a trench.
Well the reason for a subway is not because an LRT will go over capacity (it won't), but for the convenience of no transfers. The only question is how much they will spend making an over-built LRT versus a trenched subway.
$1.4 billion for an LRT in an empty rail corridor? I would hope the rails are made of solid gold.
Not quite. Lawrence & Brimley is 5km, adding only 2 stations, one of which may be able to reuse some of the STC's bus terminal area.
Using this tool: http://map.toronto.ca, Kennedy / Eglinton to STC is 4.9 km on a straight line. However, the subway won't run exactly on a straight line. Going through the Lawrence & Brimley intersection (sum of two straight lines): 5.7 km.
The new TTC report on subway versus LRT for the SRT replacement is out, for next Monday's meeting.
http://www.ttc.ca/About_the_TTC/Com...upplementary_Reports/Response_to_Commissi.pdf
It finally provides a (sort of) apples-to-apples comparison of a subway extenstion to Sheppard/McCowan, compared the RT upgrade and extension to Sheppard/Markham. Ridership on the extended SRT is projected to be 8,000 at peak hour, compared to 9,500 at peak hour for the extended subway. Capacity on the grade-separated LRT line is as high as 16,000 compared to 30,000 for subway. Based on a cost of $2.3 billion for the SRT upgrade/expansion (9.9 km route with 7 stations) compared to $2.8 billion for the subway extension (7.6 km route with 3 stations), it does say that either option is technically acceptable.
It also notes that their own original recommendation was to simply upgrade the existing SRT with new-generation vehicles as it was cheaper than LRT, and that a subway extension would have to bypass any development or growth opportunities in the Kennedy-Midland corridor.
Perhaps most importantly is stresses, a few times, that the SRT has reached the end of it's service life, that they've been recommending that immediate action be taken for a decade, that the service is now operated at reduced speed and capacity, and another prolonged debate over the future of the SRT might jeopardize Metrolinx's commitment to rehab and extend the line as LRT.
What do you think the chances are of them being able to get a speedy EA done and start design before Spadina is completed in late 2015? My reason for asking this is if we can reuse the TBMs from Spadina, it may be useful to do so. I realize the subway option wouldn't be shovel-ready by 2015, but if the EA can be done and design on-going, the TBMs can wait for a year or so.
Surely that's not the issue. Critical path is the carhouse and maintenance facility, which Inrastructure Ontario has already announced they are issuing the RFP imminently, and the contract for the SRT itself, which is to come later this winter. Surely Metrolinx isn't going to really consider a 2-year delay now, to re-examine everything. And presumably TTC isn't really prepared to put $2-billion of funding at risk for more navel gazing.What do you think the chances are of them being able to get a speedy EA done and start design before Spadina is completed in late 2015? My reason for asking this is if we can reuse the TBMs from Spadina, it may be useful to do so. I realize the subway option wouldn't be shovel-ready by 2015, but if the EA can be done and design on-going, the TBMs can wait for a year or so.
Given how loudly TTC keeps saying that the SRT is near failure, I wouldn't be surprised if they have to shut down the SRT soon anyway, whether they actually build a subway or not.The total timeline for the subway option may take an extra couple of years compared to the timeline for the LRT option, but I still think it's worth it to not have to run buses for 3-4 years while the SRT is shut down.
How do you extend the SRT life, for at least another 7 years ... probably longer.You can run the SRT into the ground while the subway is being built.
No, the worst-case scenario is if Metrolinx and the new Premier says "FU, we've already fully funded 3 different plans, we're not doing it again. There are other communities that want $2-billion in transit funding, so if you want subway, you'll have to find nearly $3-billion.The worst case scenario in terms of 'during construction transportation options' for the subway plan is the preferred option for the LRT plan.
The Scarborough LRT contract would follow closely behind. The LRTs are scheduled to arrive long before opening, and need to be stored somewhere. Not sure if the connecting track on Sheppard from Markham to Conlins is on the SRT or Carhouse contract ... but it can't be on the Sheppard East LRT contract, as that's much later in the timetable.Why would IO issue the RFP for the MSF when the contract hasn't been issued for either the Sheppard or the Scarborough LRTs
They had issued the RFQ, and then they had "suspended" it. They had never issued the RFP, let alone awarded the contract. They are simply moving forward with the RFP, finally.(it's my understanding that the Sheppard contract was cancelled when TC was scrapped, and that it needs to be started again, correct me if I'm wrong)?
It's not the bus replacement I'm worried about. It's where would you get the funding for the subway extension? The province has NEVER provided 100% funding for a subway extension before - it would get messy if they owned part of the subway line, and TTC owned another part. The province only paid 1/3 of the Spadina extension.It seems like an undesirable outcome either way. Either we're stuck with buses for 3-4 years, guaranteed, or we roll the dice and see how long the SRT will hold out before we have to replace it with buses. Even if it has to be replaced with buses for part of the subway construction period, I still consider that a worthwhile gamble.
But how could you transfer the $2.3 billion from the LRT project, as it's all PPP financing, that requires the province to retain ownership? I'd think to extend an existing subway, and maintain City ownership, you'd have to extend the payments out for a long period of time to get the same cash flow impact to the provincial treasury.Well according to the report the conversion to LRT is $2.3 billion, while the subway is $2.8 billion (the LRT price seems to have gone up, weird). That $500 million you can get from Sheppard (which I showed how in the other thread, so I won't go over it again). Suffice to say that cost difference can be covered from within the funds already allocated for Transit City, so hopefully it wouldn't get as messy as you foresee. If the cost can't all be covered with Sheppard's funds for whatever reason, $500 million isn't a show-stopper for the City to swallow on its own.
