BurlOak
The solution is not elevated, it's a Bloor viaduct style solution.The tunnels approaching Lawrence are incredibly deep. IIRC, TTC doesn’t permit grades of more than 2% for stations and 5% for tunnels. So for an elevated structure, it would have to rise to the elevated level, and descend back to tunnel level, within those grading constraints. Furthermore, towards the south of Lawrence the tracks will be curved, which will limit how steep the grading can be (IIRC, trains don’t like elevation changes on curves)
Finally, there’s the creek to the north, which the tunnels will have to navigate while descending back down to tunnel level.
At Lawrence, the subway is underground about 5 or 6m.
It crosses Highland Creek at about the elevation of the current road bridge*.
It goes underground on the north bank between the hydro lines and St. Andrew Road.
The roadway goes directly on top of the subway.**
* - the elevation of the bridge may have to be raised to pass the Regional Storm (Hazel) under the bridge. Currently, it is likely designed that if a Regional Storm comes, it overtops the roadway and possibly washes out the north approach to the bridge. This idea of mine creates a 5m high bridge which could act as a dam if the water level gets too high, and may back up water levels upstream. However, the Sheppard line over the Don Rive solved this.
** - there needs to be some small changes to the roadway. Likely Benliegh Dr. would have to be realigned, or keep a low level bridge to the north of the subway bridge that gives access to Benleigh only from (and to) the NBL.
I show this new subway bridge (and road bridge) just west of the existing, because its construction may lead to less traffic disruption.
