D
Duck
Guest
There's several ways to this works:
(4) On some (not all) of the systems, there is a rotating floor so you've got stationary level boarding for about 10 seconds until the system automatically pauses (e.g. person breaks light beam at the end of rotation). Most wheelchairs can board during this time duration easily.
For some of these gondola systems, the capsule is stationary because you're standing on a rotating platform.
you're boarding the raft from a large rotating platform.
Combined with either a rotating platform or...
I keep seeing you mention that rotating platforms are common for gondolas - can you provide an example of one? I only ask because I'd like to think I'm very familiar with many ropeways around the world, and I can't think of a single one with a rotating platform loading system.
I've seen rotating platform systems for Intamin rapids rides and other amusement devices, where the loading is done at the centre with the vehicles wrapping around the outside of the disc. But I can't imagine how this could possibly work for a gondola. The boarding is always done on the exterior of the curve through the terminal, and to have the cabin floor flush with a "rotating platform ring", the cabin would have less than 180 degrees of travel through the platform before it would have to lift up (so the platform could clear under it). The only way I could see it working is with a half-wrap 180-degree conveyor system. But again, I'm not familiar with any system anywhere in the world that operates like that.
Some 6-up or 8-up detachable chairlifts do have moving conveyor systems at the load station on one side, on the straight section before the chairs hit an acceleration tire section.
I have seen detachable gondolas where the operator can briefly pause the cabin on the short section of tires which are not driven off of the bull wheel - they are the cadencing tires which control cabin spacing/timing, so they can briefly pause it there, but then it has to rapidly "catch up" to its theoretical grip point on the rope by moving more quickly through the remaining section of the cadencing zone.
