So:
Edmonton | Ice District Tower B | 145m | 43s | ONE Properties | DIALOG
Yeah, that was my assumption too, but the old ones are still floating around on icedistrict.com and Graham's news release of winning the bid. Just seems odd to not update it all. I suspect we will see a name for this project now that the tender has been awarded.@westcoastjos I think the renders @archited posted here are the current design:
https://edmonton.skyrisecities.com/...-properties-dialog.24170/page-13#post-1240806
Indeed. My sleuthing confirms that. However, as I said, both renders are 43s, so it will be interesting to see which one we get.@westcoastjos I did confirm with Graham that it's 145m. It may in fact appear slightly taller than Manulife due to slightly different ground heights. I can prod around and see if I can get a current render out of someone, but pretty sure the one @archited posted is current.
If you can also ask about details on the slanted top ? Will it be lit and the height of that section?. Thanks @Daveography@westcoastjos I think that's an old image. I did confirm with Graham that it's 145m. It may in fact appear slightly taller than Manulife due to slightly different ground heights, but probably not as much as shown there. I can prod around and see if I can get a current render out of someone, but pretty sure the one @archited posted is current.
