archited
Ken, I do not believe that they are carelessly building without a permit (that is a fact!) but I also have faith in my own eyes vis-a-vis what has been photographed in process on site. You, on the other hand, refuse to acknowledge that they are 2 levels above the podium and are building out transfer beams at that level. The answer I believe (and have said so previously) is that their tower plans are currently in Plan-check and that they are complying with inspection requirements by going as far as they can before their permit is approved by way of completion of Plan-check (i.e. they are not covering anything up that needs to be inspected once the building permit is issued). And as to @Avenuer's comments about Development Permit's approval for 25 Storeys for the tower being considered -- it just might be that the hold-up for Building Permit Approval might be related to an increase in tower height and a reworking of the Development Permit (subtended by extra work being developed at the Parking Level/Footings level).
So -- to be very clear -- I believe that if there is no building permit issued for the current above podium work on the second residential tower that is situated on the currently existing podium base, then Qualico and thereby Ledcor are prepping for work that will fall into a "current" status by building out as much as they can -- pre-inspection -- while their permits are being readied (perhaps "Development" and most certainly "Building").
