Again that's assuming that it will have a skip stop pattern, which while according to
@smallspy is what the TTC wants to do, from what I've seen Metrolinx say so far, it seems the plan at least at launch is to not skip stops at all. If you want to keep to a consistent headway, allowing LRVs to skip stop is the easiest way to absolutely kill that and to introduce bunching into the system as we see with Viva in York Region or the Toronto Streetcars (In York Region, while Viva Blue did operate every 7.5 minutes off peak, you would quite often see a situation where busses start to bunch up and you have a bus 4-5 minutes after the last, and the next bus 10 minutes after that. This persisted even after the new rapidway opened). Also, if the LRTs does skip stops, remind me exactly what the difference between Line 6 and the 510 is again, and why are they branded differently?
