adma
Superstar
I have no problem with genetically engineered appliances.
Just think of the magnetic field around that thing.
Now induction is just a newer (less tested) version
Is induction better?
Yes much better control and much more efficient than gas.
How can you have better control than gas, does it cool the pan when turned off? Coils yes, because those just continue to retain heat after the knob is turned, but gas no.
Gas uses less electricity
by controlling the energy that induces the eddy currents in the cookware.
It's a fact, even though you seem to be disturbed by it, that induction heaters are more efficient then gas. Gas is about 40% efficient, induction in the high 80's.
Your comment about coils indicates that you're not familiar with how induction stoves work.
BTW, can you simmer over a very low heat with gas...not using a "simmer plate" either. Can you maintian a fixed temperature in the cookware with gas? No , but you can with induction.
Apparently you need very powerful gas burners, since 60% of the heat energy is lost to the atmosphere.
Induction uses no gas![]()
Again, you seem to think induction is better at all times - and it is not.
Yes, it goes down to 500 Btu (.1 kW)
Again, you seem to be attempting to put words in my mouth. I was simply dispelling the myths you hold on induction. You seem to think gas is the best...and it's not.
In other words, no, you can't get the flame low enough.
how about maintaining a fixed temperature?...you skipped that question.
you guys are both wrong!
charcoal is the best to cook with. Mmmmmmmm carbontastic! way better than putting heated rocks from the fire inside a concave surface filled with water and using that to boil food or suspending animal carcasses over a lava flow.
indoors? what are ya, some sort of future boy?![]()
