In 2014, the tree seemed to be doing fine.
Started to decline in 2016.
A shell of itself this summer.
Probably construction damaged the root system. Another reason we should not let any construction happen anywhere in the city :p - don't let the local NIMBY group see this...
When plans with a high level of detail go to council, the institutional culture, enforced by council calling out admin when plans aren't followed, is that changes require going back to council. So even if things don't make sense anymore, unless the change is needed, or not making the change will result in failure, the change is not made.
This. Very this.
Those look to me like Siberian Elms, which do not handle Chinooks very well. As much as I hate seeing mature trees cut down, unfortunately with Siberian Elms they just aren't well suited for our climate and experience massive die offs every few years. I've had to remove many.
That's too bad, I quite like those trees, there is a big one just off the pathway beside Point McKay, that tree almost looks like an Oak or something from a distance.
The bureaucracy not being able to be the bureaucracy and the need to go back to the elected officials for everything being the issue with something as small as a curve in a sidewalk is wild. I completely believe it though. It speaks to a lot of our development issues. To have to go that far back up the chain to remove a curve in the sidewalk shows how broken things are.
As someone who has consulted on recent City streets project (not involved in this one). I highly doubt that this decision/change required going back to a councillor or even beyond one or two levels of managers. Without having any inside knowledge here, I suspect this was more of a case of rushing to get this stretch of work done in the late fall, and not having time to remove the large tree root balls before building the pathway. Maybe they will go back next year and reconstruct it, but I doubt it.
